droyd opened this issue on Oct 13, 2001 ยท 3 posts
droyd posted Sat, 13 October 2001 at 12:25 AM
bloodsong posted Sun, 14 October 2001 at 4:38 PM
Attached Link: http://www.3dmenagerie.com/index-goo.htm
heyas; not bad, there! :) if you poke through the tutorials section, you should find some tutorials about combining two figures together. as long as your blends are not on any body part seams, this should work well for you. it doesnt look like you'll have that problem, as i can see the horse foreleg bit blending in with the raptor thigh bit, there. you should parent all the raptors (i'm guessing there's 3) to the horse body, and then select the horse body and save to the figure library. this should save everybody all together and let you reload it whenever you need this character. the only real problem i forsee is the two front legs. you might have to go with one raptor each for those legs, and parent each one to the horse's forelegs. that will make it rotate properly. once you have the whole conglomeration in a cr2, you can go about editing it to cut out the unneeded bits. (ie: all the invisible parts!) you can check out the gryphon version 4 at my goodie page, created by jelisa and myself, to see how two eagles were blended with the p4 lion to create the gryphon. it isn't as complicated as this setup you've got, but its the same idea. (even if you dont have the eagle, you can look in the cr2).droyd posted Sun, 14 October 2001 at 4:52 PM
Hi bloodsong, Thanks for the reply, that's 2 I owe you! I'll see if I can figure this out. I'm still pretty lost when it comes to this stuff. I'm sure I'll be bugging you again when I get close to making this work. Edit the cr2? Now I'm scared! droyd
