Dreams2Fly opened this issue on Oct 14, 2001 ยท 12 posts
Dreams2Fly posted Sun, 14 October 2001 at 9:15 AM
Kixum posted Sun, 14 October 2001 at 3:56 PM
Just for fun, you could duplicate the pencil body, shrink it to 99.9%, move it forward just a little bit and apply your wood texture to it. Then do the same thing but re-boolean with a hollow cylynder leaving you just a narrow cylinder with the pointy ended lead. That should provide you the pencil lead when you retexture it. You may end up with visible edges and you may not. I don't know anything about UVMapping but from what I undertand, cutcopypaste is probably correct for a truly pure result.
-Kix
Dreams2Fly posted Sun, 14 October 2001 at 7:16 PM
alexabel posted Mon, 15 October 2001 at 12:37 PM
Dreams2Fly posted Mon, 15 October 2001 at 12:55 PM
Don't tell anyone, but Amapi makes me feel like I have rocks in my head. Are there any good tutorials you can point me at to learn that program? Carrara is at least similar enough to Ray Dream 3D that I could figure out the basics pretty quick.
alexabel posted Mon, 15 October 2001 at 1:56 PM
Try http://www.eovia.com/amapi/tutorials/mar2000tut/english/default.htm
willf posted Mon, 15 October 2001 at 11:43 PM
alexabel has a good approach, that can be done very easily within the spline modeler in Carrara. Just make cross sections where the shapes change, make three duplicates & then delete cross sections from each duplicate as needed to build the 3 parts. The other alternative is to use the elevation with wiggle feature in the blender of the shader.
Dreams2Fly posted Tue, 16 October 2001 at 6:56 AM
The problem I had with making the whole pencil body in the spline modeler was the curves where the cone intersects the hex barrel. If I use the splie modeler, I'm stuck with a less realistic look of a sharpened pencil--at least to my eyes. I want those curves of yellow to match the shape of the model. If I can keep my computer from freezing up, I will try the Amapi approach this evening.
Kixum posted Wed, 17 October 2001 at 5:32 PM
Good job alexabel! I need to learn Amapi pretty hard. Very cool that you did that. Since you say it would be easy in C, it might be nice to do it and then post the solution. -Kix
-Kix
fabien_nguyen posted Thu, 18 October 2001 at 4:23 PM
Attached Link: http://creafab.free.fr
I often use RDS and Amapi. Some tutorials are on my web site, but thy are in french. CREAFab, la crtion numique autrement...Dreams2Fly posted Thu, 18 October 2001 at 4:50 PM
Thanks, fabien_nguyen. It'll take me a while to figure out what it all says (my last french class was more than 12 years ago!), but the Amapi tutorial looks liek I may learn alot from it. BTW, you have several broken image links as viewed from Netscape 4.78.
fabien_nguyen posted Fri, 19 October 2001 at 1:37 AM
Thanks. If you ever need a translation of some part of my tutorials, just ask me ! Thanks for the warning about the broken links. It's strange because I had checked all the links with Netscape 4.7 and 6.1. I'll try to fix that. CREAFab, la crtion numique autrement... creafab@free.fr
