L&A opened this issue on Oct 15, 2001 ยท 8 posts
L&A posted Mon, 15 October 2001 at 11:17 AM
Do someone have a tutorial for the joint editor. I want to make a wing with separate parts and I want to bend them but it mess up. Can someone provide help?
PhilC posted Mon, 15 October 2001 at 11:39 AM
You may find the info contained in the previous thread of benefit. In it you will see how a wing may be grouped to produce the motion required. Other than that I go into a lot of detail regarding joint parameters in my Modeling for Poser 4 CD.
wgreenlee1 posted Mon, 15 October 2001 at 1:45 PM
hehehe,PhilC to the rescue!
SAMS3D posted Mon, 15 October 2001 at 2:12 PM
Attached Link: http://www.sams3d.com/Tutorial.htm
You could also download my tutorial, it will give you answers for the joint editor....hope it helps. Also, you can go to http://www.posertech.com SharenL&A posted Tue, 16 October 2001 at 8:05 AM
Thanks PhilC but unfortunately I don't have enough money to spend on buying CD's. You fix my right wing and I'm trying to do the left one but I never learn how to do my joints. I used the same wing but with a reflection and try to fix the joint but am unable.
wgreenlee1 posted Tue, 16 October 2001 at 12:23 PM
SAMS3D posted Tue, 16 October 2001 at 1:36 PM
maybe info from www.posertech.com might help you. Sharen Just click and read the section you need.
L&A posted Wed, 17 October 2001 at 8:09 AM
Thanks every body esp. SAMS3D. Even if I was able(I don't know how) to fix the prob, your tut look like very good and could be helpful. PhilC I'll finish the work and put a message here to show you the result. Thanks
