pokeydots opened this issue on Oct 19, 2001 ยท 21 posts
pokeydots posted Fri, 19 October 2001 at 8:39 PM
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
2.80GHz, 4000MHz System Bus, 2MB L2 Cache + 6MB Shared L3 Cache
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphics
System Ram: 8GB
LaurieA posted Fri, 19 October 2001 at 8:53 PM
Well, you asked ;). 1. I think the inside of the mouth is too pink and much too light in color. 2. Could you consider any other eyeshadow color than green? I know I personally used to avoid that color because I looked rather like a ghoul when I wore it ;). 3. The crease marks on the lips are too much straight up and down. Maybe angle them out a little more as they approach the sides of the lips. 4. The eyebrows are a bit too dense. You may want to thin them out just a little bit. Other than that, I think it looks okay. Certainly better than I could do ;). Laurie
pokeydots posted Fri, 19 October 2001 at 10:15 PM
Thanks I will thin the eyebrows and work on the lip lines, I knew the tongue was to pink so I will fix that too :) Thanks :)
System Ram: 8GB
pokeydots posted Sat, 20 October 2001 at 2:11 AM
System Ram: 8GB
DTHUREGRIF posted Sat, 20 October 2001 at 2:42 AM
This is looking really good. Couple of suggestions. The eyeshadow looks much better, but try softening the eyeliner with a smudge brush. It's too dark and harsh. Also, clone out the highlights from the eyes (I'm assuming you used a photo for the irises). dina's cornea layer will let you make very convincing and more realistic highlights by adjusting the reflection. Also, try making the wrinkles on the bottom lip less straight up and down. They should follow the curve of the lip.
LaurieA posted Sat, 20 October 2001 at 3:53 AM
Wow! That's much better pokeydots! :). I agree with Diane on the lips and eyeliner, but what an improvement :). Laurie
Ms_Outlaw posted Sat, 20 October 2001 at 4:01 AM
Like the stud earrings to. Cute.
leather-guy posted Sat, 20 October 2001 at 4:37 AM
Wow, with the lips closed, the texture really looks SO much more realistic! Nice work on that latest render, I much prefer the more natural look myself, so to my taste, the lipstick is too vivid, but I know I'm in the minority, there. Wonderful Progress! - Started on the body, yet?
VAIRESH posted Sat, 20 October 2001 at 6:27 AM
Lookin' good Poketdots ;-) 2 suggestions... Lower eyelashes need to be less well defined. Try using a finer line in your graphics program to make them. The edges on the eyebrows look to harsh, try softening then a bit. I have Dina and know how thin the actual outer mesh is so you may just want to put them on the actual face map so you can make them more feathered ;-)
pokeydots posted Sat, 20 October 2001 at 7:30 AM
Ok, I'm gonna give it another try :) lol, by the way those are my lips on her :) so MY lip lines are off! roflol And the eyebrows are painted on the texture,, so a thinning I will go!
System Ram: 8GB
pokeydots posted Sat, 20 October 2001 at 9:26 AM
System Ram: 8GB
pam posted Sat, 20 October 2001 at 10:32 AM
looking very good! Each version makes great leaps :-) pam
islandgraphics posted Sat, 20 October 2001 at 3:55 PM
This is really good Sallie! Everything looks great! (I ain't crazy about the eye shadow but that's just me...) One thing: The eyeballs are too white... you need some red lines in there or, otherwise, she'll look like a Visine ad! ;o) (WOW, is it me or does that tongue look real?) -Nathalie
pokeydots posted Sat, 20 October 2001 at 4:27 PM
oops! lol thats my tongue too :) I have lines and shading in the eyewhites, but I can't figure out why it doesn't show, I will try and fix that :) Thanks Nathalie :)
System Ram: 8GB
pam posted Sat, 20 October 2001 at 4:44 PM
Pokeydots, I have found that the colors in the eyewhites tend to get washed out, I think because poser eyes are set to be very reflective. To compensate, I either make the texture much darker/richer than looks right unrendered, or set the material color to a cream color, so that gets multiplied into the texture
DTHUREGRIF posted Sat, 20 October 2001 at 4:51 PM
Wow, that tongue IS great! Sallie, the lip thing may be happening because of the way you are applying the lip photo to the map. If you look at a straight on photo of lips, you will see that the lines appear to curve inward toward the mouth toward the edges. If you are applying a 3/4 view photo to the map or one that was taken at an angle from below, you will get lines running the wrong way. One easy way to fix this is to use a liquify brush and push the lines a little.
DTHUREGRIF posted Sat, 20 October 2001 at 4:59 PM
pokeydots posted Sat, 20 October 2001 at 8:55 PM
Okey dokey, I will try try again :) Thanks!
System Ram: 8GB
SQS posted Sun, 21 October 2001 at 3:58 PM
OH, WOW!! This look like a photograph!! REALLY great job!!! Now for the eye whites?? Amazing!!! Did you put your tongue on the scanner???@!!#!
pokeydots posted Sun, 21 October 2001 at 5:49 PM
Thanks ! And no I didn't put my tongue on the scanner!! lol I have a digital camera :) Hmmm but I do have dentures, maybe I could scan them for the teeth!!!
System Ram: 8GB
RealitysPoison posted Sun, 21 October 2001 at 8:40 PM
Looking really good. My one suggestion would be to tone down the nostrils a little bit. I know we don't want them glowing, but I personally don't like to see them looking like an obvious brown spot. One suggestion would be to "smudge" some of the face into the nostrils. It makes it a little more subtle of a shift.
