Kolschey opened this issue on Oct 22, 2001 ยท 4 posts
Kolschey posted Mon, 22 October 2001 at 8:44 AM
c1rcle posted Mon, 22 October 2001 at 10:53 AM
I'm not an expert but if you get hold of UVmapper from the freestuff you can make a new texture map then recolor it with that, that's the best way I can think of to fix the problem, hope this helps mate :)
ElectricAardvark posted Mon, 22 October 2001 at 5:21 PM
IMHO: One should consider any new obj import to be "unmapped" when bringing it into Poser. With that in mind run it through UVMapper, and then import it. Not all 3d modellers import/export along the same xyz coords.
Kolschey posted Tue, 23 October 2001 at 6:53 AM
It looks like I'l have to play with UV mapper, then.Thank you both for your help!
