Forum: Poser Technical
Subject: "Warning can not open Runtime\Libraries\..."
classic opened this issue on Oct 25, 2001 ยท 2 posts
classic posted Thu, 25 October 2001 at 2:14 PM
I have been editing Poser files to create new light sets, poses, etc. Most of the time I simply drop the new files into appropiate folder my Poser install and it works. Although occasionally I get the following message when I try to apply my new file to a pose:
"Warning can not open RuntimeLibraries..."
Anyone have any idea what is going wrong? I am always including a new RSR with the files (made with a little application called RSR Converter) so Poser should be able to find and apply the new pose. Also I am careful that the new file and its RSR have the EXACT same names (but different extensions of course).
Any info would be greatly appreciated.
brycetech posted Fri, 26 October 2001 at 1:08 PM
could be that the file is 'read only' could be that you have poser open and the file is in use could be that you have given it a wrong name (spaces count) could be that you need to reboot your computer occasionally could be that something else is happening on your system at the same time that causes a hiccup and a call is missed lots more top three would be the 'read only' one poser is using it and the need to reboot
