Wind_Caster opened this issue on Oct 27, 2001 ยท 9 posts
Wind_Caster posted Sat, 27 October 2001 at 5:50 PM
Bia posted Sat, 27 October 2001 at 5:58 PM
oh she's cool. Is that the Pat bump on her or is that her own bump? I think it's looking great. I will have to have her if I can afford her! I think there is an eyebrows gone morph in free stuff... :)
Cin- posted Sat, 27 October 2001 at 6:04 PM
Is this Posette or Victoria? If it's Victoria, you'll want to check to make sure that ALL of the "eyebrows" materials are set to the same color as the "skinhead" mateial, including hightlight and ambient color settings...
Wind_Caster posted Sat, 27 October 2001 at 6:05 PM
This is Viki 2
DEFx$ posted Sat, 27 October 2001 at 6:32 PM
Try the morph "browgone...Its on the head defxs
melanie posted Sat, 27 October 2001 at 8:20 PM
Make sure you put transparency only on the UPPER eyebrows, not on the base eyebrows. What you're seeing is a hole into her head because you probably have transarency set to 100% on both Eyebrows and Upper Eyebrows. Only the Uppers need the transparency. Give it a try. Melanie
shadowcat posted Sat, 27 October 2001 at 9:37 PM
For victoria the material labeled "eyebrow" is the skin beneath the eyebrow. "upper eyebrows" is the part that uses a transmap and is the hair. the "brows gone" morph will not fix this.
LaurieA posted Sat, 27 October 2001 at 10:46 PM
Check this thread. I gave visuals, so that should make things easy :) Laurie
LaurieA posted Sat, 27 October 2001 at 10:47 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=363681
Oops...guess I should post the dang link ;)
