Skygirl opened this issue on Nov 05, 2001 ยท 13 posts
Skygirl posted Mon, 05 November 2001 at 12:17 PM
How do you make those props that have doors that can open, drawers that can be opened, boxes with lids that can open and all those kind of things...how in heavens name do you do ? Do you prop the different parts together in Poser or what ?!? Sky...confused as always... :-)
c1rcle posted Mon, 05 November 2001 at 12:30 PM
have a look on the Sams3d site there's a great tutorial on how to do just that,they give you everything you need to make your first posable prop,sorry can't remember the address, hope this helps
Skygirl posted Mon, 05 November 2001 at 12:51 PM
Itll certainly be excatly what I need. Thanks a lot :-)
Cybermonk posted Mon, 05 November 2001 at 12:53 PM
You can move some stuff by morphong it. But most of what your talking about is making a multi part object into a figure. ScottA has a good tutorial on it here A Renderosity. Sams3d has some tutorials on there site too. A quick example: You make a box with a lid in yor favorite modeling program. Export it without welding or joining any of the parts you want poseable. In this case the lid and bottom 1/2. You bring it into Poser (after making a good texture template in UVmapper). Now select the object and open up the grouping tool and spawn prop. This will break the object up into its componet parts. Delete the orginal to get it ot of the way. Now go into the hiearchy editor and put either the lid under the base or vice versa. I'd put the lid under the box in this case. Now go in to the joint editor and adjust the lids centr of rotation near where the hinge should be. Now go back to the hiearchy editor select the model and then click create new figure. Delete one you have(its not a figure) an load the one from the library. Voila! Hope that made some sense.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Cybermonk posted Mon, 05 November 2001 at 1:00 PM
Oh yeah forgot to mention in the case of the box you would want to select the bottom 1/2 of the figure and select properties and turn off bend. Else when you pose the lid It'll warp the box.
Albert Einstein
SAMS3D posted Mon, 05 November 2001 at 1:28 PM
Attached Link: http://www.sams3d.com/Tutorial.htm
Yes, go and get the tutorial, it will help you and help you understand Poser more. Sharen www.sams3d.comSAMS3D posted Mon, 05 November 2001 at 1:29 PM
Thanks also c1rcle for the compliment too. Sharen
Skygirl posted Mon, 05 November 2001 at 1:51 PM
Thanks to all of you. In this forum you really know how to help each other. Thanks again ! Sky :-)
c1rcle posted Mon, 05 November 2001 at 2:30 PM
free advertising never hurts :) I've been going round at work telling all my mates "get poser, go to renderosity and check out all the links from there" I've convinced 1 person to buy poser and he's just waiting for it to arrive then he's going to join here. I just wish I had some more money, there's so many great things I want to buy, happily some of the best freebies I've found are on Sams3d.
SAMS3D posted Mon, 05 November 2001 at 2:56 PM
Oh man, you are too kind....thank you so much. We have 2 more coming this week. We are trying to do at least 2 high detail maybe even poseable freebies per week. Thank you for the compliments. Sharen
thgeisel posted Mon, 05 November 2001 at 3:00 PM
thanks sharen for the good tut. I dl it and read it,very usefull!!
robert.sharkey posted Tue, 06 November 2001 at 3:14 AM
Attached Link: http://www.cybergate-corp.ch/webdesig/poser3/download/Figure_Tutorial.zip
Have done a Tutorial the last days because some others requested the same thing. It reflects all steps trough assigning materials and groups in UVMapper and doing the PHI-file and poserizing. At end you have room as figure-file with opening windows and doors. The objects which i used for the Tut where included. Good luck. SHARKEYSkygirl posted Tue, 06 November 2001 at 3:52 AM
Thanks to you too Sharkey. Funny, but I have this stranges feeling that I cant get enough Poser-tutorials ! Sky :-)
