Aeneas opened this issue on Nov 05, 2001 ยท 3 posts
Aeneas posted Mon, 05 November 2001 at 4:50 PM
when you right click the desktop and go to "new", PS puts an entry there called "adobe photoshop image". i can remove it with a tweak ui type utility, but as soon as i open PS again it puts it back. how can i keep PS from putting that entry on the "new" menu? probably a register setting...
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Beretta619 posted Fri, 09 November 2001 at 2:11 PM
AFAIK, you cannot remove it permanently. Adobe likes to pull that stunt with all their products. I have an entry for Photoshop and THREE for Pagemaker! I think the programs are hardcoded to check for, and add those darn entries. I've used TweakUI to remove them, I've even directly edited the registry, and they keep coming back. Really torques me off.
Aeneas posted Sat, 10 November 2001 at 6:22 AM
Thanks. I'm afraid you're right. There will probably a Registry key that can be set to a different value or something like that, but, unless I know for certain that someone pulled the trick with no disastrous side-effects, I stay out of there. As for Adobe: they probably do it because in their opinion it is helpful , so...
