Johndalynne opened this issue on Nov 06, 2001 ยท 5 posts
Johndalynne posted Tue, 06 November 2001 at 8:22 PM
I recently aquired the program from he "POSER ++" site to create water dropplets, the only problem is I don't get how you are suppoed to make dropplets into hair files so it can work. Does any one has a clue or am I clueless?
PabloS posted Tue, 06 November 2001 at 10:16 PM
I haven't used the water dropplet program but I have played around with the fur-fur program some time ago which I believe is similar. As I recall you select the object you want to put droplets on and type "hair" (an undocumented poser function). Fiddle around with the settings, export the object and run it thru the droplet program...I think. The fur-fur program may be better documented and can probably give you some insight on how to use the droplet program. Hope that helps.
Kalypso posted Wed, 07 November 2001 at 1:19 AM Site Admin
Masa had a tutorial on how to use the program at his site. As I recall it was split into two, a beginner's and advanced and made things very clear. So check under his tutorials section.
SAMS3D posted Wed, 07 November 2001 at 4:20 AM
Where do you get this Poser ++ and who is Masa? Sharen
Kalypso posted Wed, 07 November 2001 at 5:11 AM Site Admin
Sharen, Masa has developed some great utilities taking advantage of the hair easter egg in Poser to make fur and water droplets. Also he's the creator of MTMirror for morphs. You'll find his stuff and a few other items hosted for Yamato at http://www.eurus.dti.ne.jp/~masasi/ Poser++ is the name of his site :) Kalypso
