Alcofuel opened this issue on Nov 07, 2001 ยท 5 posts
Alcofuel posted Wed, 07 November 2001 at 10:08 AM
Im using Bryce 4 & I was wondering if it was possible to make a boolean operation with two mesh objects ( so one cuts out the other). I am able to use a regular Bryce shape as a negative object & cut it out of a mesh but when i use a mesh object the negative mesh just dissapears. This is frustrating as i need to cut out irregular shapes (that i've made in other 3D apps). Also i find i cant cut a mesh shape out a regular object. Someone PLEASE tell me this is possible as i love Bryce & boolean opps!
brycetech posted Wed, 07 November 2001 at 12:17 PM
select the mesh objects click the "e" check "solid when boolean" then make your boolean luck ;P BT
Alcofuel posted Thu, 08 November 2001 at 1:37 AM
Thanks a lot thats really helped me out.
EricofSD posted Thu, 08 November 2001 at 3:26 AM
Do it all the time. You can boolean an inverted mountain into a right side up mountain and have lots of fun with it.
clone_technology posted Thu, 08 November 2001 at 10:39 AM
ooh yeah =)
