Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 7:57 am)
You should make certain that you remove all the links to the body part you are removing. Also, if you remove a body part you need o remove all the dependancies, so if you remove the arm you need to get the fingers, etc. The body parts are all listed in at least three places in the file, plus the relative references.
Ok, I tried making a new figure using pdblack's method of renaming the pz3 file to a cr2 file and then editing the cr2 with the CR2 editor on the free stuff pages. Problem is when I opened the newly created cr2, I caught the dreaded 'C' exception, which probably means I edited too much. SO, here is my question, are there items in the cr2 that I have to make sure I do not delete? Do I need to keep all the figure and body lines? Can I delete body parts, or do I have to keep them all and just make them invisible? Thank you for any helpful suggestions in advance.
