Ghostofmacbeth opened this issue on Nov 11, 2001 ยท 9 posts
Ghostofmacbeth posted Sun, 11 November 2001 at 9:35 PM
Weird question I know but does anyone know where the exact point where the nostril is on the Michael map? I am trying to get rid of the glow and since the nose is more pug than normal it is worse than normal. Thanks
AprilYSH posted Sun, 11 November 2001 at 9:50 PM
hmm, just set the object colour in the materials editor to grey or brownish - try as dark as you need till the glow goes away. i don't know cos i don't have michael, just a guess from remapping dork's nostrils :)
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
Ghostofmacbeth posted Sun, 11 November 2001 at 9:57 PM
I would try that but too much of the nostril is showing ... It only affects the top of the nostril and wih the nose he has in my character I nees a little more.
AprilYSH posted Sun, 11 November 2001 at 10:20 PM
um, just looking at the template, there doesn't seem to be a spot for michael's nostrils except directly on the head area, so you can't paint right inside it... unless you remap it to spread out better. i could be totally off without the silly model to look at %) vicki has the nostrils mapped out, iirc, i would have thought mic would too. wanna show a preview of your character? :)
shadowcat posted Sun, 11 November 2001 at 11:18 PM
look for the michael seam guide from snow sultan in free stuff.
Cin- posted Sun, 11 November 2001 at 11:35 PM
You can cheat like I did for Vicky, run it through UVMapper, select everything, hide everything, then select the nostrils material, show it, and then save the MAP... copy and paste it into your texture map, and then you can see exactly where you need to make adjustments... just make sure that the two images are the same size before you paste. :)
shadowcat posted Sun, 11 November 2001 at 11:36 PM
Ghostofmacbeth posted Mon, 12 November 2001 at 7:13 AM
I was afraid of that ... didn't think to check the seam guide until after I posted this. I was sleepy S thanks all. Hope I can get in there and all.
duanemoody posted Tue, 13 November 2001 at 1:48 PM
When I had to fix this problem for my Heline character (based on Posette) before 3DCommune would agree to sell it, what I did was use the Grouping tool to set the nostrils aside as a separate material. Since Mike already has nostrils as a material, you can use the Grouping tool to add polygons to the nostril material until you're satisfied. I'd go that route and skip the whole UVMapper thing altogether.
