azl opened this issue on Nov 16, 2001 ยท 5 posts
azl posted Fri, 16 November 2001 at 5:45 AM
I know how to use PHI Builder to create figures that refer to OBJs in the Geometries folder. But how do I create a prop referring to an OBJ in the Geometries folder? Do I simply change the extension on the CR2 file and remove certain lines? If so, what lines do I remove? Thanks.
Traveler posted Fri, 16 November 2001 at 6:06 AM
Attached Link: http://www.morphworld30.com/tutorials/externalcalls.html
I have a tutorial for that at Morph World:azl posted Fri, 16 November 2001 at 7:15 AM
Thanks, Trav. That was perfect.
Traveler posted Fri, 16 November 2001 at 7:29 AM
No problem at all :) BTW, that same trick works for hair files as well. I keep meaning to add a note to that effect on the tutorial. -Trav
nyar1ath0tep posted Fri, 16 November 2001 at 2:58 PM
Eric, there's one more instance of the prop name, down at the bottom -
doc
addActor propname
I reckon that has to be renamed as well, but since we are usually keeping the prop name the same after deleting the vertex lines, it's probably not critical.
