Subject: Did anyone make a no-glow nostril for Vicky?
velvetdream2 opened this issue on Nov 18, 2001 ยท 4 posts
velvetdream2 posted Sun, 18 November 2001 at 11:17 AM
I found the one for P4 male/female but no Vicky.
Jaager posted Sun, 18 November 2001 at 1:30 PM
Comes with them.
dvlcat posted Sun, 18 November 2001 at 2:18 PM
It does? Where is it found and how is it used? Thanks.
Jaager posted Sun, 18 November 2001 at 2:52 PM
The material has its map in the center of the map. DAZ has it as a part of the head layer. It is a bear to texture there if you use the head layer.
I use a separate map and just have continuous skin there on the head texture. Using a dark Poser color probably does well enough. But because of the overlap, if you use the head layer, either you get skin on NOSTRILS or you get too dark a texture on the skin around the nares. ( there is demo in a thread below- yesterday or the day before- that shows the effect of being too generous with the Nostrils colors on the head layer.
material Nostrils
Until Bloodsong decided to make the bottlecaps inside the nares a new material in P4 so that it was not just skin and thus get rid of it, there was a glow in the renders.
DAZ incorporated this same refinement in Victoria and Michael from the outset.
