kumo opened this issue on Nov 24, 2001 ยท 4 posts
kumo posted Sat, 24 November 2001 at 11:14 AM
can anyone tell me how to install iso's kimono please, i have done it the same way as all the others but all i get is the grey dudes,please help me coz i need it for a geisha texture i am working on, the files are obj,png,cr2 &jpg many thank KUMO
Kalypso posted Sat, 24 November 2001 at 3:33 PM Site Admin
If you've installed it following the directions you'll have a file in your characters library called ISO_KIMONO. Inside should be the .obj's and cr2's of ALL the items (don't forget the third zip that has common files for both kimonos). The .png's are worthless to you if you don't have Pro Pack, that's why you get the shrugging guy. The files will still open though, have you tried them? You can always resave them again so that Poser will build up an .rsr with the thumbnail.
wotsupdoc posted Thu, 14 March 2002 at 2:44 AM
I'm having problems too, but of a different kind. The only 2 .obj files that I have are: mune_type1.obj which is used by anego_mune.cr2 otaiko.obj which is used by anego_obi.cr2 However, the files anego_sodeR1.cr2 and anego_sodeR2.cr2 need the (missing) file: tome_rev1.obj and tome_rev2.obj The file anego_suso.cr2 needs the (missing) file: suso_type1.obj The file anego_zoriL.cr2 needs the (missing) file: zori_L.obj The file anego_zoriR.cr2 needs the (missing) file: zori_R.obj So out of 7 objects only 2 objects (mune and obi) work. Does anybody have the files (or knows whwere I can find it): tome_rev1.obj, tome_rev2.obj, suso_type1.obj, zori_L.obj and zori_R.obj? As far as I know it is a free model, as ISO himself writes: "This data is free for Personal use". So no copyright infringement will be involved
Kalypso posted Thu, 14 March 2002 at 3:09 AM Site Admin
Everything was posted on Iso's site. There were two kimonos and a third file necessary for both. Maybe the .obj's were all there. Unfortunately, his site is down at the moment as he's redoing it and hopefully they'll all become available again shortly.
