Kiera opened this issue on Nov 25, 2001 ยท 9 posts
Kiera posted Sun, 25 November 2001 at 7:37 AM
I have Bryce 4.01. I am trying to render a fairly complex scene (almost every object has at least minor reflectivity, several light sources, several imported objects) to disk so I can get a 300dpi image to postprocess for print. The image renders fine on screen at large and small sizes. However, if I render to disk (72 dpi or 300dpi) it always crashes at different points. I have plenty of disk space, spatial optimization set to high, anti-aliasing to normal quality. Am I missing something here or am I going to have to do the old "render at 72 dpi, scale up to 300dpi, and blur a lot" trick?
dg3d posted Sun, 25 November 2001 at 10:11 AM
Do you have a Screensaver installed???? With Bryce 4.01 i was doing render to disk for print and never got a crashes. Pleiades
Kiera posted Sun, 25 November 2001 at 12:30 PM
Nope, no screensaver. I even turned off sleep mode, just to be sure. It's all very strange.
dg3d posted Sun, 25 November 2001 at 12:51 PM
Do you have any anti-virus software installed with real-time proctection???
thgeisel posted Sun, 25 November 2001 at 1:41 PM
never had problems with render to disk, no clue :-((
EricofSD posted Mon, 26 November 2001 at 12:48 AM
What's the speed of your hard drive? I've encountered problems with low speed drives. Need to shoot for 8 to 10 megs/sec. 7 works ok. 2-3 megs/sec sux.
Kiera posted Mon, 26 November 2001 at 9:44 AM
No anti-virus software. I turned off all background processes. The drive I render to is at least 10 RPM, but the drive bryce is on is slower. It's a pain because you can't resume crashed disk renders, so I changed my resolution to 1600x1200 and rendered to screen so I could resume if it crashed. It's still not the right resolution, but the image rendered fine to screen, so it's not a problem with any of my objects or my scene file.
thgeisel posted Mon, 26 November 2001 at 12:35 PM
its really hard to say , why you have those problems. maybe try to render to the disk where bryce lives on, maybe some powersaving options aktivated,i can only guess..
Kiera posted Mon, 26 November 2001 at 1:59 PM
I was just curious if anyone else had had this problem. I don't normally do high res bryce scenes because I render for wallpapers and such and was just curious if anyone had had this problem before. Thanks everyone for your input. =)
