Subject: Vicky lost her clothes again
ronknights opened this issue on Dec 04, 2001 ยท 6 posts
ronknights posted Tue, 04 December 2001 at 11:55 AM
I have been rendering the recent Mike & Vici poses from Schlabber, the Pose Master. Everything is going smoothly till I got to this gymnastics pose. Vicki literally lost her bikini! This is the first time I saw this problem in this recent batch of poses....all others went absolutely fine. I thought I'd try "lock actor" with both the bikini top and bottom. It did no good with this pose. So did I do something wrong? Is there a fix for this? I used a bikini, for convenience, on all the Vicki poses I'm rendering. They didn't come with rsr files, so I am going through all them, rendering, and adding back to the library.
Lisas_Botanicals posted Tue, 04 December 2001 at 12:19 PM
I've noticed that strange things will happen to clothes when pivoting the hip on the "Y" axis. Stopping at 180 will skew the clothes wildly but at 179 or 181 they will pop back on. Perhaps is the hip setting and you should try to increase or decrease the "X" "Y" or "Z" setting by one.
duanemoody posted Tue, 04 December 2001 at 1:21 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=224046
Perhaps it's gimbal lock, where Poser gets confused about axis rotation... Check out the link.
jnmoore posted Tue, 04 December 2001 at 3:51 PM
Lisa is right, I've seen the same thing. You could try conforming the clothing again, sometimes that helps.
ronknights posted Tue, 04 December 2001 at 6:11 PM
Thanks forthe tips. "Gimbal Lock" doesn't seem to apply if I am reading right... even if it does, the solution was not there. I tried conforming, no good... I tried lock actor, no good. This only happened in a few "upside down poses." So I took of Vicki's bikini and made her pose nude for the rest of those poses.
Crescent posted Tue, 04 December 2001 at 7:27 PM
Ya know, most people here don't seem to have a problem with a nude Vicki ... ;-) What if you select the bikini and restore the figure then try to conform it to Vicki again?
