Larry F opened this issue on Dec 10, 2001 ยท 21 posts
Larry F posted Mon, 10 December 2001 at 2:49 AM
So I opened several old PeeZees, of which none have this. Then loaded into one of them one of the current figures, crashing that particular PeeZee.
So ran a lot of other different programs, i.e., Vue, Bryce 3, etc. No apparent abnormalities.
So anybody got any idea of this? Am about to reinstall, which I hope fixes it.
Thanks in advance.
Larry F
JeffH posted Mon, 10 December 2001 at 3:18 AM
Looks like the welds are being ignored in the CR2s. I'm assuming you're on a Mac - Pro pack on that OS is still a bit under done IMO. -Jeff
eirian posted Mon, 10 December 2001 at 3:24 AM
Well, before you reinstall, try going into the Runtime/Geometries folder. If you look for the .obj files for the models you're having trouble with, each .obj will have a corresponding .rsr in the same folder. Delete the .rsr's. That will force Poser to rebuild them, and does fix a lot of problems. But the image looks like it could be a different problem, I'm not sure. I ended up with an effect like that when I was creating my Duncan character: it happened when I kept making changes and resaving the .cr2. I could move the settings over manually to a "blank" cr2, resave and get rid of the gaps. But the first version, even though the morphs and settings were identical, ended up useless. I don't know what caused that. I guess a reinstall would fix it, though.
Larry F posted Mon, 10 December 2001 at 3:33 AM
JeffH,
No Mac here. Win98 PIIi 933, 512, 32 MB Nvidia, etc., etc.
Don't know what happened. Just used Poser all day Saturday, fine as usual.
eirian, thought about that, at least in your first paragraph, but this is EVERY figure Will try a deleting a few of teh .rsr's, see what happens.
Starting to think I may have gotten a bug from somehere, though I like to think I'm protected, or perhaps moer likely a soft spot on the hard drive.
But life's an adventure, and hey, thanks.
Larry F
JeffH posted Mon, 10 December 2001 at 3:45 AM
Does this happen with Poser4.0 without the Pro Pack? Try that.
Larry F posted Mon, 10 December 2001 at 3:51 AM
Looks like my day off today is already laid out for me. Sigh.
Been kind of a strange week the last few days anyway.
JeffH posted Mon, 10 December 2001 at 3:53 AM
Your copy of poser is definately ignoring all OBJ welds in the CR2... Start from scratch and reinstall from Poser4.0 up..
Larry F posted Mon, 10 December 2001 at 4:00 AM
Gee JeffH, I don't think I have Poser 4 still. That is, ProPack went over it. I could remove PP then (OUCH!) reinstall Poser 4 (will have to hunt down those updates, too) from the ground up. Wondering if I might have to reformat or replace my HD (OUCH! again) but I've everything backed up, a result of previous experience. Still, drastic as this seems, that would probably fix it, but sure would hate to still have the problem after all that. Thanks again.
Larry F posted Mon, 10 December 2001 at 4:05 AM
I think we crossposted, JeffH. Gonna have to bite the bullet (now where did I put it?) I guess. Thanks again.
EdW posted Mon, 10 December 2001 at 6:44 AM
Do you have the ProPack update 3 installed? This is a known problem with the ProPack. It messes up the obj file and has some extra vt lines in the file that don't reference anything so you get the holes in the mesh. The updaters corrected this problem. Ed
ronknights posted Mon, 10 December 2001 at 7:38 AM
When you see this type of problem, the most obvious questions are: 1.) If you're using "the regular Poser," have you installed the update to 4.03?! 2.) If using the Poser Pro Pack, did you install the latest Service Pack? Until you can say yes to both questions, don't waste your time doing anything else.
ronknights posted Mon, 10 December 2001 at 7:39 AM
By the way, if you handle any uninstalls or reinstalls correctly... you will still have your runtime folder. However, it may somehow be messed up since Poser ProPack handles some things differently....no rsrs, etc. You might consider backing up all your runtime folder.
ENGELKEN posted Mon, 10 December 2001 at 8:38 AM
Maybe that's what's happening in yours.
eng
ronknights posted Mon, 10 December 2001 at 8:49 AM
ronknights posted Mon, 10 December 2001 at 8:50 AM
Jackbox posted Mon, 10 December 2001 at 1:18 PM
Display->Bend Body Parts? i guess
Larry F posted Mon, 10 December 2001 at 2:40 PM
Everyone, thanks for all this great input. I did finally "fix(?)" it by resetting to factory state. Have had a preferred state set in ProPack since I got it months (a year?) ago and frankly never seem to have any of the problems I've seen mentioned around here.
I don't have the latest service pack updater - come to think of it I don't know if I ever got one - no problems to speak of over the course of time.
About the service packs, do I have to install them in order of release or can I just jump to the latest one and install that? Seems I read somewhere one needs to do the former.
Thanks again.
Larry F
Tomsde posted Mon, 10 December 2001 at 3:02 PM
I just got Pro Pack and I believe the most recent updater does everything. Check the Curious Labs website for specific information.
ronknights posted Mon, 10 December 2001 at 3:17 PM
Attached Link: http://www.curiouslabs.com/products/proPack/html/proPackServiceRelease3.html
You need to go to the Curious Labs site to get the PRo Pack Service Release. Go there nowLarry F posted Mon, 10 December 2001 at 3:29 PM
I'm there. And thanks!
ronknights posted Mon, 10 December 2001 at 4:41 PM
Any time.
