Subject: Converting Bum files???
cwshorty opened this issue on Dec 11, 2001 ยท 8 posts
cwshorty posted Tue, 11 December 2001 at 12:27 AM
I've seen reference made to this several times along with instruction on how to do it just the other day of course I can't find them now. Can someone point me the right direction for learning how to do this. I have the jpg files now, but need to convert them to .bum files, I'm assuming I can't just change the extension. LOL
Thanks for any help at all.
thgeisel posted Tue, 11 December 2001 at 12:51 AM
start poser,you dont need to add a figure or such, go to "render" "surfaceproperties" go to "bumfile" ,"load" and load the jpg-file.Poser asks if the file should be converted, "yes" and its done. poser adds the new bumfile to the same folder where the jpg is
cwshorty posted Tue, 11 December 2001 at 12:59 AM
Oh Bless you, thank you so much for your help!!
ronnieversace posted Tue, 11 December 2001 at 2:24 AM
I have read this instruction before, but it doesn't work for me. My Poser just accepts the jpeg and doesn't ask me if I want it converted. Is it because I use ProPack or am I possibly doing something wrong?
thgeisel posted Tue, 11 December 2001 at 4:03 AM
if you have propack you dont need to convert. propack uses the *.jpg direkt as bumpmaps without converting.
ronnieversace posted Tue, 11 December 2001 at 4:27 AM
Coolerz. I thought that was the case. Now I know for sure. Thanks.
cwshorty posted Tue, 11 December 2001 at 4:10 PM
I'm using the Propack but wanted to create a bum file for a non propack user.
Little_Dragon posted Tue, 11 December 2001 at 4:49 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=487037
If you have Pro Pack installed, Poser will not convert to .bum, even if you have it at gunpoint. You'd have to install a second copy of Poser, without the Pro Pack upgrade, in a different directory, and use it for .bum conversion.
You could also try running an emboss filter on the .jpg in your favorite paint program, saving it as a greyscale .bmp, and then renaming it to .bum. The file formats are almost identical. See the thread above for details.
