Subject: How to Transfer a Morph?
Ricky_Java opened this issue on Dec 12, 2001 ยท 4 posts
Ricky_Java posted Wed, 12 December 2001 at 4:18 PM
I'd like to transfer the "Pregnant" morph from DAZ's Victoria 2 to WyrmMaster's Voluptuous Vicki 2.1, and I hope someone more experienced than I can give me some guidance. I downloaded Mr. X's Morphman utility this morning from http://www.greylight.com/poserutil.html. Morphman works without error messages, copying the code from Victoria 2.cr2 to VoluptuousVicki2.cr2. I've opened the VV2 cr2 file in Wordpad and confirmed that the Pregnant code is there, but no Pregnant parameter dial shows up when I load her in Poser. I've looked in the Hierarchy Editor, clicked Show All Parameters, and I don't see Pregnant there among all of VV2's morphs. I also tried transferring the morph by copying the relevant text from V2 to VV2 with Wordpad: same result. I'm concerned that my little model is gonna explode if she can't start showing soon. Can anyone help? - Ricky
Cin- posted Wed, 12 December 2001 at 6:22 PM
Are you trying to transfer the full body morph (the one that shows up when you have the "Body" selected), or all of the individual pregnant morphs for each body part? I could be wrong, but I don't think MorphManager will copy a full body morph properly, so you'd have to transfer each body part's morph target... you can create a new full body morph though once you get them moved over... just be sure you don't have any other morphs applied when you create the full body morph... Hope that helps. K-
Jaager posted Wed, 12 December 2001 at 9:32 PM
Here is how: Copy the V2 cr2 to another folder. Change the extension to= pz2 Open this in MM4 (you must change the file type. Open the VV2 cr2 next to it. Copy the morph channels over: in Body and in each group where it actually resides.
Ricky_Java posted Sat, 15 December 2001 at 8:56 AM
Thank you Cin- and Jaager. Jaager, I followed your excellent instructions to the letter, and it works beautifully! Also, I found version 4 of Morph Manager over on the 3D Comic Collective site, and I'm sure that helped too. I hope I can return the favor someday. Ricky
