Forum: Community Center
Subject: Logging on
chrisjol opened this issue on Dec 15, 2001 ยท 3 posts
chrisjol posted Sat, 15 December 2001 at 5:38 PM
I'm having problems logging on. For a start I'm suddenly presented with a logon form instead of automatically getting in. Then my password is refused several times before it is accepted. I haven't altered my cookie. Any idea what's going on?
RimRunner posted Sat, 15 December 2001 at 6:52 PM
One thought that you could try.. once you are logged in.. select the Log Out option from the side-bar. This will remove the "old" cookie from your system. Then log in again, if it's a problem with the cookie, this should cure it. Also, the site is Case sensitive.. so if you have a mix of upper & lower case in your password.. :) HTH - James
The doctor says I have way too much blood in my caffeine system.
chrisjol posted Sat, 15 December 2001 at 7:01 PM
Thanks for that, James, fixed the problem, you're a star!
