Subject: converter
monkey_boy opened this issue on Dec 26, 2001 ยท 3 posts
monkey_boy posted Wed, 26 December 2001 at 1:36 PM
where can i get a jpg to bum converter or how do i do it????thanx
brittmccary posted Wed, 26 December 2001 at 2:14 PM
Poser will convert the file when you apply the bump-map. You'll get a question if it should convert.. and then just select "yes" Britt
Nance posted Wed, 26 December 2001 at 6:19 PM
IIRC, it will unless you are using P4 and are opening a figure created in ProPak with the jpg's already applied as bumpmaps. (could be very wrong here!) If so, prior to opening the figure, load & apply all its jpg bump maps to a simple prop and let Poser convert them first.
