whoopdat opened this issue on Dec 28, 2001 ยท 16 posts
whoopdat posted Fri, 28 December 2001 at 3:21 AM
Swannie posted Fri, 28 December 2001 at 6:15 AM
Jim Burton posted Fri, 28 December 2001 at 7:21 AM
Looks great, much better! Now that your ready for Hair 202, let me suggest you throw in some "wild" hairs, if you look at most close-ups you will see a couple slightly out of place ones (or sometimes greatly out of place). I even put "wild" hairs in my Poser hair mesh, it adds to the effect.
vervefx posted Fri, 28 December 2001 at 9:46 AM
Whoopdat... This looks like a great start. This is actually as far as I ever get. Swannie.... What brushes do you use? What's the size you use for smudging the hair? Mine, comes out looking clumpy and not natural at all. V
Lorraine posted Fri, 28 December 2001 at 10:56 AM
Ok I put the stray hairs idea in for you, basically it is a series of layers using the "#1" brush in photoshop or a very small brush, put in a few hairs at a time varying the type of brush and layer, screen, luminostiy, burn, darken, lighten etc. then vary the lighting on the layer and the opacity until it starts to look the way you want. Another thing to think about is shadows...pick up the color of the dark shadows around where the hairs are and brush in shadows on the face on a separate layer and then work them in a little. Also don't forget that the erase tool, using the brushes is a good way to work in the detail you want...this took about 10 min to do...
Lorraine posted Fri, 28 December 2001 at 11:02 AM
Lorraine posted Fri, 28 December 2001 at 11:05 AM
whoopdat posted Fri, 28 December 2001 at 12:13 PM
Again, thanks for the wonderful ideas and suggestions. I see some things now that I've had a chance to sleep on it that I missed or that I'd like to have done differently, but I also see I have a ways to go yet. I'll take these suggestions and give it another shot and maybe have something to new (and better) to show for it in a few days. Thanks again. You're all rather encouraging!
Lorraine posted Fri, 28 December 2001 at 12:54 PM
Well don't forget to post your new images...hair is something that takes a little patience, but it is your ideas that make it work. The examples are just that, often it is just the touch of a shadow a stray hair here or there or a subtle application of the burn tool that changes the "look" of the image....
vervefx posted Fri, 28 December 2001 at 10:23 PM
Lorraine posted Fri, 28 December 2001 at 10:41 PM
just try using the screen setting on either the brush or the layer or both, light wispy strokes or long light strokes work best...put in a few strokes here and there go to a new layer then go back and start adjusting the layers...it is not too hard just takes a few minutes and if you don't like it delete it....also hair will add to the energy and movement of the image.....
Lorraine posted Fri, 28 December 2001 at 11:29 PM
vervefx posted Sat, 29 December 2001 at 3:32 AM
Thanks Lorraine That's the feathered look I'm going after. Gonna go work on those fly aways :) V
Lorraine posted Sat, 29 December 2001 at 7:17 AM
well I have exaggerated it a bit for purposes of illustration; I hope it is helpful. The final result should be more suited to your view of the hair, smoother softer or heavier....flyaway or "organized" ...I hope you will post more of your images....
movida posted Tue, 01 January 2002 at 12:35 PM
found this searching for something else, might be worth reading although it's specific to Corel Painter go here: http://www.seegmiller-art.com/Images/tutorials/hair/hair1.html
