Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 7:57 am)
I downloaded a couple earlier today and this did not happen, however I have seen this 'randomley' both here and other sites. I have No idea what causes this, I just always attibuted it to the particular server or method the file is posted? The only place I have seen this 'consistant' is Eric's Prop Club (formally Bbay Club where it happened consistanly as well). Since I am particular about keeping my temp files cleared daily it's never a problem for me, but I have wondered. Depending on your download software and method, mine (IE5.5 SR3 with no funky stuff added) and with WinZip Browser plug-in installed, I get the option to unzip at the end of the download. This way I can direct the unzipping as soon as the file is delivered. For this reason I direct most downloads to C:temp anyway, then 'clean house' at the end of the day.
my friend, from what I heard I think u may have set up your brownser that way, perhaps somehow u may have check a seting that says, hide this window or something like that, meaning your brownser is doing all the work automaticly.... if u have netscape these settings are somewhere under edit preferences, than u must find cause I don't exactly remember where, if u have internet ex. will be under internet settings on your control panel, assuming your are usin blowindows... it may not even you who did anything, sometime a prog will go crazy or so.... anyways my comp almost talks to me....hehehehehehhe hope I've been of some help one other thing, I'd sugest creating a folder called netdownloads or whatever but to make sure u download everything there, .... it will make life a lot easier....
Got the same problem, randomness and all. It started happening to me about 2 weeks ago and it really bugs me. I still have not got a solution. Could it be some "GatesLand" server-software-update containing a bug or new option that some download sites have begun to use? Looking for answers as well! STORM
Hi first of all i want to thank you for your messages to Sherry and I before i went away for Christmas. You made us smile and very happy :) We both hope you all had a wonderful Christmas :) Ok now i have noticed that when i try to download some of the wonderful files from the freestuff section, most of the times now they just start saving to my temp folder and i have to go and hunt them down amoungst everything that is in there. Not an easy task if you try. Before i usually got a pop up to choose location to download to, you know the usual save as one. Is this a new feature or is it a bug or is it maybe the way the files are upload that is causing this? Thank you God Bless RodPanther
