glennjan opened this issue on Dec 30, 2001 ยท 7 posts
glennjan posted Sun, 30 December 2001 at 8:46 AM
I select a charactor from the library and pose it the way I want now how do I get the charactor to open in that pose automatically ...I tried saving it back to the library but it opens in the previous pose instead of the new one... Is there a way to do this or do I have to use the memory dots...I would like the new posed charactor to be the default when I select it instead of reposing or starting from the default pose??????????? Thanks
Jim Burton posted Sun, 30 December 2001 at 1:51 PM
Gee, it should be saved with your settings, if it isn't try Edit/Memorize-Figure and save the set again.
pragask posted Mon, 31 December 2001 at 11:07 AM
There are one or two buttons for uploading the character from the library . Use the 'New Figure' option .
geep posted Sun, 06 January 2002 at 12:58 AM
If you use the "change figure" (1 check mark) button,
your figure will load with the pose of the previous figure.
If you use the "create new figure" (2 check marks) button,
your figure will load with the pose that you saved it with.
Then select the "old" (previous) figure and "delete" it (if you want to).
cheers,
dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 06 January 2002 at 1:00 AM
... save the pose you want in the "pose" library.
Change your figure and then reset the pose from the pose library.
cheers, (again)
dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
doozy posted Sun, 06 January 2002 at 7:23 AM
Are your pose use the "body" of the figure?
glennjan posted Sun, 06 January 2002 at 9:50 AM
Thanks for the help..I saved the pose to the pose library now I just apply when I open the charactor..maybe I didnt have the body selected the first time .......or maybe I needed more sleep less coffee....lol.......thanks
