Morzog opened this issue on Jan 06, 2002 ยท 3 posts
Morzog posted Sun, 06 January 2002 at 9:14 PM
I was doing a tut on lighting effects. When it came to the last section it was on the Texture Channel. It said you could apply one of the R G B channels as a texture or you could apply one of your own channels that you had saved. My problem is I can not figure out how to save an image as a channel. If anyone knows how this is done would you be so kind as to help out a newbie? Thanks
dreamer101 posted Sun, 06 January 2002 at 11:30 PM
You can copy and paste. eg. make a selection of an image you want to use as a texture and Ctrl-C (or Edit - Copy). Go back to your image you want to apply the lighting effects texture on. Click on Channels tab, click on Create New Channel icon at bottom of palette, Ctrl-V (or Edit - Paste). Click back on the Layers tab and select the layer you want to apply the effect too. When you go to Filter - Render - Lighting Effects, select Alpha 1 (or whatever you renamed it to) from the Texture Channel at bottom of the Lighting Effect dialog box and click OK.
Morzog posted Sun, 06 January 2002 at 11:50 PM
Thanks that did it. Man Photoshop rulez!
