sturkwurk opened this issue on Jan 07, 2002 ยท 6 posts
sturkwurk posted Mon, 07 January 2002 at 2:13 PM
because I've hit a wall a couple times, outputting a texture from photoshop at a very hi rez... poser seems to choke on them and displays them very funky... so my question is, what is the max pixel texture size in Poser 4/Pro? Thanks, Doug
I came, I rendered, I'm still broke.
geep posted Mon, 07 January 2002 at 6:05 PM
... I've used 4k x 4k without any problem. How much RAM do you have? What OS?
cheers,
dr geep ... :o]
edited 10/5/2019
sturkwurk posted Mon, 07 January 2002 at 6:43 PM
768 ram running Win2k Pro.
geep posted Mon, 07 January 2002 at 9:33 PM
A 4k x 4k (.bmp) texmap can require up to 48MB. The same 4k x 4k (.jpg) texmap only requires about 18MB. I only have 384 Meg and run Win98. So you should be able to use at least a 4k x 4k map. This also depends on how many other figures/objects you have active at the same time. I have had 4 figures with high res maps active but it definately slows thing down. You might also want to check your swap file settings. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
sturkwurk posted Mon, 07 January 2002 at 10:24 PM
geep posted Mon, 07 January 2002 at 11:48 PM
... 4,001 x 4,001? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
