Subject: render_separate.py - Python script to render each figure and prop separately.
markdc opened this issue on Jan 08, 2002 ยท 8 posts
markdc posted Tue, 08 January 2002 at 6:39 PM
Attached Link: http://poserutils.tripod.com/index.html
see: http://www.renderosity.com/messages.ez?ForumID=12390&Form.ShowMessage=257428&Reply=441049#25
Python script to render each figure and prop separately. (Child props and conforming clothes are rendered with the figure).
In freestuff.
jamball77 posted Tue, 08 January 2002 at 10:43 PM
thanks for the heads up.
timoteo1 posted Sun, 13 January 2002 at 2:31 AM
I saw Python store ... very cool scripts. I'll probably pick a few up. However, I noticed you had a script to fix heels for walk-designer animations. CAN YOU MAKE ONE TO FIX THE WD "LEG SPAZZ" BUG? That would be wonderful !!! -Tim
timoteo1 posted Sun, 13 January 2002 at 2:38 AM
There was no documentation with the download. What EXACTLY does the render seperate script do? When done, I take it you need to comp the files together in After Effects or something right.
markdc posted Sun, 13 January 2002 at 2:56 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12390&Form.ShowMessage=257428&Reply=441049#25
Please see the original request which explains the purpose of this script. Try turning of IK to fix the leg spazz bug.
timoteo1 posted Sun, 13 January 2002 at 3:55 AM
Thanks for the link, I'll check it out. Tried that ... I've tried EVERTHING! If you adjust any of the parameters (even slightly) you get RIGHT leg spazz. A simple jog is impossible in Poser without the Spazz. I have been using Lifeforms to make custom BVH's, or using masing camera angles. But what a pain! It renders the WD useless IMHO. -Tim
markdc posted Sun, 13 January 2002 at 1:30 PM
I'll take a look at this.
timoteo1 posted Sun, 13 January 2002 at 6:30 PM
Wow, thanks! That would be wonderful. I have seen scores of animations here on R'osity and they all exhibit the dreaded "legg spazz." I think some people just don't notice or just don't care.
