Subject: Need a set for your images? How about 33 seperate set props?
lalverson opened this issue on Jan 13, 2002 ยท 9 posts
lalverson posted Sun, 13 January 2002 at 9:57 AM
Attached Link: http://www.renderosity.com/softgood.ez?ViewSoftgood=6417
Want to add more depth to your poser images? Want to have a room, or house, or a hallway? Would you like to have a choice as to how much set you need for your image? if the answer to any of these is yes then this combination kit is what you are looking for. In this kit you get ALL 3 AFA construction kits(Tudor,Asian,Rustic). Thats 33 props. All indidivualy materialed so you can choose what textures you would like to use. Each Material is easily labled for clear concise use. All of the 33 props are pre-scaled and pre-centered in poser4 for easy re-location within you image document. Now you can easily build just the set you want. walls and windows where you like them. Build a room, a tavern, a dojo, a log house. Now you have easier control of lighting, since you only load what you need, you can build a set like tv or movies. If you were to buy these kits seperatly, they would cost you $40 dollars. For you can get this combo kit for ONLY $30 (that's like getting the rustic kit for free), Also, once your order is confirmed you will also receive the freebie kit that normally goes with the tudor kit. For a taste of how AFA construction kits are made and work you can download for free the Urban kit, located in the freestuff section here or on my site at www.n-link.com/~lalverson just follow the links to the 3d downloads
