Impudicus Rex opened this issue on Jan 13, 2002 ยท 5 posts
Impudicus Rex posted Sun, 13 January 2002 at 5:01 PM
bloodsong posted Sun, 13 January 2002 at 5:37 PM
heyas; there's a sorta picture chart at masa's site (last time i looked) that shows what each option does. hmmm... the latest mtmirror had a preview window you could open. did you try that? are you sure your morph target is asymmetrical? after you mirror the right to the left, mirroring the left to the right... um, will give you the same thing, i think. since you made both sides the same already. other than that, i really have no clue, because i usually can't get past the 'not symmetrical' stage in loading the base :/
Jaager posted Sun, 13 January 2002 at 6:00 PM
Which side did you do the morph on? If it was the right, then that side is already what you want. Mirror right to left and you have your morph - symmetrical. Mirror left to right and you erase your morph. Swap and your right side morph is now left side and right side is base, or whatever you did to the left by mistake. Your mistake is using Poser export for the base. It might work, but I don't trust it for this. Open the cr2 and the obj in MM4, choose the head, right click, and I think you can Export To Geometry. If you did the morph in Poser with magnets, get it into the cr2 as a morph, you may have to Export to morph target and apply this as a morph target. I don't know, I don't use the magnets. Select this morph and Export To Geometry from MM4. MTM is easier to use if you put the base and morphs in the same folder with the .exe . bloodsong, Make sure your base is a single group, or the matched pair, if the group is not on the center line.
Impudicus Rex posted Sun, 13 January 2002 at 6:14 PM
Thanks guys. I'll try it again.
dwilmes posted Sun, 13 January 2002 at 8:01 PM
CR2Edit will also mirror morphs, 2 ways, depending on just what you are trying to do: in the OBJ, or the CR2. Dan http://www.zenwareonline.com for CR2Edit, ZenPaint, ZenTile, VueMaster and the complete line of Zenware graphics apps
