Rancidvolcom opened this issue on Jan 14, 2002 ยท 5 posts
Rancidvolcom posted Mon, 14 January 2002 at 12:49 PM
cambert posted Tue, 15 January 2002 at 5:07 AM
You can import it into Bryce as a 2D picture, not a 3D object. In Photoshop, select the background all around the figure and save the selection. This becomes the alpha channel that Bryce needs for transparency. Save the file in Photoshop format (ie .psd).
In Bryce, in 'Create' mode, click the 'Leonardo' figure. In the screen that comes up, you'll see three large squares (with the Leonardo pictures in them) and a bunch of smaller squares below. The first small square should have Leo in there too. Click the second one and locate the image file you saved in Photoshop. It should load the image into the first big square, the alpha channel into the second, and the figure with transparent background into the third (the result of the first two combined. Click OK and your figure is in your scene.
Don't know about Poser, don't use it. Good luck with it.
Rancidvolcom posted Tue, 15 January 2002 at 8:18 PM
Thanks bro, great help on this site
synergyauto posted Fri, 01 February 2002 at 2:13 PM
If you really wanted a mobius 3d character that could be used in bryce, pick up UV Mapper. From there it's just putting skin over wireframe on some parts and not on others.
Rancidvolcom posted Fri, 01 February 2002 at 3:29 PM
Ok, that'll work...but what are you doing answering posts that are a month old??? :)
