Forum: Bryce
Subject: A quick question, and hopefully some answers...
Depheant opened this issue on Jan 16, 2002 ยท 8 posts
Depheant posted Wed, 16 January 2002 at 8:00 AM
This is in Bryce4- I have a scene, and I want to have a streaming light effect coming from behind some trees in the background. Unfortunately, when I use the spotlight and set it up- nothing happens, except that the render time goes up significantly, even though there is no visual difference. Also, I have noticed that if I remove a radial light then the spotlights are visible; thing is that I need the radial light and also the spotlights with the streaming light effect. Any ideas?
Lightpen posted Wed, 16 January 2002 at 2:20 PM
A quick Idea would be to go to Corel and look carefully at thier tutorial on the new Light Lab. I am sure it will not answer every question but it just might give you the right direction. Be pleased! Lightpen
Kate posted Wed, 16 January 2002 at 6:50 PM
And to see the new light lab you would/could try a copy of the scene in Bryce 5 demo version
ringbearer posted Wed, 16 January 2002 at 9:21 PM
Attached Link: http://www.brycetech.com/tutor/bryce/stream1.html
Brycetech has a great tutorial on streaming lights. Maybe this will help.
There are a lot of things worse than dying, being afraid all the time would be one.
Depheant posted Thu, 17 January 2002 at 10:39 AM
Heh, thanks. I did not notice that tutorial before, even though I regularly visit the site.
thuffner3 posted Fri, 18 January 2002 at 5:42 AM
How about adding a really faint dust cloud, something light for the light to reflect from. In actuallity that's what causes the light strams in the first place. Dirt in the air. Hope that helps.
joke posted Fri, 18 January 2002 at 12:42 PM
Bryce volume light has a rendering error. It happens when you have a volume light and another light (non-volume). If a shadow generated from the non-volume light hits on the volume light that volume light part gets cut off.
Depheant posted Sat, 19 January 2002 at 5:26 AM
So- I should disable 'Cast Shadows' for the non-volume light? And, thanks for all the help people. I think I might just add the streaming lights in PhotoShop-if I can find a tutorial.
