Subject: Poser Figures in Cartoon Display
Wampyir opened this issue on Jan 17, 2002 ยท 17 posts
Wampyir posted Thu, 17 January 2002 at 1:44 PM
Hi, everyone. I was wondering, does anyone know of any way to have textures display on Poser models when Poser is set to display as Cartoon w/Lines? Seems every time I add a texture map to a character, like to a piece of clothing, and then choose Cartoon as display type, the texture map disappears, showing only the underlying or default color of the object. About the only feature I've been able to find that I can add to basic cartoon display is anti-aliasing. Any and all help is appreciated; thanks!
VirtualSite posted Thu, 17 January 2002 at 1:50 PM
I dont think you can. The whole point of the sketch render is to simply provide a basic idea of what the image looks like by breaking it down into simple fields of color.
nyar1ath0tep posted Thu, 17 January 2002 at 1:51 PM
  1. Export the poser figures as an obj file to a folder holding all associated textures. 2. Import the obj file to Carrara, and use the "Toon" post-render filter, which has several adjustments, like sharpness, shadows and line thickness.
Little_Dragon posted Thu, 17 January 2002 at 2:09 PM
Cartoon with Lines mode isn't bad, so long as you're willing to work within the limitations of the medium. The above pic was created entirely with Poser (no postwork, except for a mild blur filter and resizing), using Michael 2 and Maz's build-it-yourself cartoon dungeon kit.
If you want toons with textures, you could render your image normally (texture-shaded mode), and then load the image into a paint program and apply cartoon filters.
A recent thread discussed this issue. Look here for details and a link to some PhotoShop-compliant plugins.
Mesh_Magick posted Thu, 17 January 2002 at 10:22 PM
What, like this?
Mesh_Magick posted Thu, 17 January 2002 at 10:24 PM
heres a figure that is a hybrid of sketch and render mening ts cartoon outlined with rendered qualitys.
Mesh_Magick posted Thu, 17 January 2002 at 10:26 PM
this was done useing a 2 step filtering process, If you want to know More let me know and Ill continue this thread.
Mesh_Magick posted Thu, 17 January 2002 at 10:31 PM
rendering and cartoonline traits are present with this process.
Mesh_Magick posted Thu, 17 January 2002 at 10:32 PM
original image
Mesh_Magick posted Thu, 17 January 2002 at 10:37 PM
this was the orginal image for the cartoon mike pic posted at the top. Ill check back later to see if anyone is interested in this look, If they are Ill blow the top off the little secret process that made these images.
Mesh_Magick posted Thu, 17 January 2002 at 10:45 PM
By the way that is a great Michial Jackson peeking around the brick wall you did.
Puntomaus posted Fri, 18 January 2002 at 2:01 AM
LOL, Mesh Magick, I thought the same :-) BTW, I read a good tutorial about cartoon render on Shanim's website (http://www.aerysense.com).
Every organisation rests upon a mountain of secrets ~ Julian Assange
Puntomaus posted Fri, 18 January 2002 at 2:31 AM
Here is an image I did using the technique Shanim describes. I did not add textures, just colored everything and applied Antialias Document, that's all.
Little_Dragon posted Fri, 18 January 2002 at 2:58 AM
Drat. Thanks for the kind words, but I was going for Dr. Jones, not Mr. Jackson.
Oh, well. These days, he is almost that pale.
In all fairness, it is Michael. Michael 2.
Puntomaus, would you please tell me exactly how to find the tutorial on Shanim's website? I'm having difficulty finding it.
Puntomaus posted Fri, 18 January 2002 at 3:52 AM
Little Dragon, I've just been to the website and searched for the tutorial but it looks like it is gone. It once was in the download section. Maybe if you send an email to Shanim asking for the tut?
Little_Dragon posted Fri, 18 January 2002 at 4:09 AM
Thanks, I'll consider that.
Here's "M.J." again, from a different angle. :)
Wampyir posted Fri, 18 January 2002 at 9:55 AM
Yes, I'd like to see the Shanim tutorial as well. All of these examples are wonderful; thanks everyone!
