Illo opened this issue on Jan 17, 2002 ยท 6 posts
Illo posted Thu, 17 January 2002 at 8:43 PM
I 've downloaded a bunch of free PC/Mac props over the past year, and I rarely find instructions in the Read-Me text for loading the Conforming/Morphing props into the correct files on a MAC. Can anyone break this out for me?. Kozaburo's hair props have me completely confounded. Also, should the PC/Mac prop be run through something like MacConverter first? Thanks!
JeffH posted Thu, 17 January 2002 at 8:48 PM
Yes, use Maconverter always unless the file was created on a Mac.
jnmoore posted Fri, 18 January 2002 at 7:03 AM
Go to Martin C's web site http://MartinC@soft-rabbit.com/ and download Both Mac Converter and Mac Installer. After you've run the files through Mac Converter, drop them -one at a time- on the Mac Installer Icon and it will load them into Poser for you (check off the box labled copy unrefferenced textures before you click on OK). Jim Moore
Illo posted Fri, 18 January 2002 at 1:11 PM
I'm still confused. If a prop from the Freestuff area is labeled as PC/Mac, why run it through MacConverter? Why not label it as a PC prop? Also, how would I know if a prop was created on a Mac? Thanks for your help so far.
RonGC posted Fri, 18 January 2002 at 1:48 PM
I always run the files through MacConvertor. It wont hurt the file and will just convert those that need conversion. Use it and your problems should go away :-) RonGC
nyar1ath0tep posted Fri, 18 January 2002 at 3:35 PM
They label some files "PC only" because they don't know about MaConverter, although .exe files (apps) are always "PC only". They label other files "PC/Mac" because it's the default setting for freestuff. It's almost always the correct setting, thanks to MaConverter. Most of them are PC files. They label files "Mac only" if they're .sit files. So those can sometimes be used on a PC with Expander, unless they're Mac apps.
