BigKabuto opened this issue on Jan 20, 2002 ยท 9 posts
BigKabuto posted Sun, 20 January 2002 at 12:32 PM
PhilC posted Sun, 20 January 2002 at 12:51 PM
Select the helmet and go to Object/change parent. In the popup window select the figure's head (ensure that you do not mistakenly select the clothing). Click the "OK" and the helmet should now stay with the figure.
BigKabuto posted Sun, 20 January 2002 at 1:04 PM
nope still doesn't work...could you try it out? make a simple male figure in poser4, insert the obj helmet you can find it on free stuff..just type helmet..it's the green soldier helmet..
Little_Dragon posted Sun, 20 January 2002 at 4:34 PM
PhilC's method works for me. Maybe this will work, instead. Select the helmet. Go to the Object menu and select Properties. Click the Set Parent button and choose the figure's head from the popup window. Click OK. Now try moving the head.
BigKabuto posted Sun, 20 January 2002 at 4:37 PM
very weird , normally it would always work...but it just doesn't
stewer posted Sun, 20 January 2002 at 7:26 PM
You can also change parenting in the Hierarchy Editor, try it there.
doozy posted Mon, 21 January 2002 at 12:58 PM
You can find it on free stuff ?? Searched "allied" nothing found. Searched "helmet", many found but not that one. Searched "bigkabuto" nothing found.
BigKabuto posted Mon, 21 January 2002 at 1:42 PM
I didn't make the helmet, but just download this one..search helmet Helmet for G.I.Joe by Rexxzilla
Little_Dragon posted Mon, 21 January 2002 at 7:48 PM
Found it; it was posted by jerr3d. It isn't the model itself. I can parent it to the head, and it moves along fine.
