Subject: "We are not amused"... Conforming????!!!
brittmccary opened this issue on Jan 21, 2002 ยท 27 posts
brittmccary posted Mon, 21 January 2002 at 5:34 PM
The coronation chair - prototype is done.. I'll have to take it down in file size, it's REALLY big. But it's coming along pretty nicely, I think. It's not far away from the original either :) But before I texture it, - I'll make it smaller in file size BUT.. this is Posette, and the dress that comes out of the pack. I just posed her... (wonderful sitting poses from Swanie!), and put on her dress and checked "use limits", - conform to... and the dress doesn't want to obey! If that is a problem with the dresses out of the bag, - I don't even want to think about the conforming coronation dress I'm modelling. What am I doing wrong?? Britt
Little_Dragon posted Mon, 21 January 2002 at 5:47 PM
You're not doing anything wrong. It's all Poser's fault. Bad Poser! Bad!! No treat for you! Conforming will only go so far, especially on stuff like dresses, cloaks, and flowing garments. It's a limitation of the current technology. Things should be better in Poser 5 ... ... but for now, we're stuck with magnets and postwork.
brittmccary posted Mon, 21 January 2002 at 5:54 PM
Phew!!! lol Glad you told me this before I started to pull more hair out! OK... then I know that not all the conforming errs are MY fault. Hmm... but how does one model a skirt to get a "sitting" pose with as little flaws as possible?? Posing her, - and then export her, - and model the dress when she's sitting?? Britt
Kiera posted Mon, 21 January 2002 at 6:00 PM
Steve Shanks has been working on seated poses for skirts. Something to do with using props. Perhaps he modelled two separate items.. one seated and one standing? I am not sure. Perhaps he would take a minute to comment on his technique. The pictures at Poser World Fairy Woods were quite impressive.
Strangechilde posted Mon, 21 January 2002 at 6:09 PM
One thing you can doand this is a really inelegant solutionis to create a new group using the grouping tool on the model for the pieces where the skin pokes through the mesh, and then set the transparency for that group to 100%, max and min, highlights and reflections black. That way you can have the same effect as, say, making the legs invisible to get them to quit poking through the trousers, but still having legs to poke out from under the skirt. Magnets can make the clothes fit, but I usually just patch holes in postwork. I'm lazy that way. :P
Little_Dragon posted Mon, 21 January 2002 at 6:26 PM
Jim Burton has a new idea for conforming dresses and the sitting problem; look here.
hauksdottir posted Mon, 21 January 2002 at 7:44 PM
I always dress a character, and conform or parent the various pieces, BEFORE posing. This ought to help you, since the stuff is designed to line up with body parts in teh default position and move from there. Carolly
Jaager posted Mon, 21 January 2002 at 8:05 PM
Morphs. ERC morphs on the clothing controlled by the joints of the figure are the way to have it done automatically. If twer that easy, we would be awash in them. A conforming skirt is difficult. One of the main problems is the IK chain requirements. The R buttock cannot touch the L buttock, nor R thigh, L, nor R shin, L. Hip or some neutral must separate them. The intervening group does not move with either leg. Sitting would be a particular problem because both legs would be horizontal and the hip between them vertical - straight down from the groin. As for a morph to move the hip section: the sort of morph that I find most difficult to do is one that is a hinged rotation. The fact that modeling programs have rotation functions, seems like it should be easy. Unnn-fortunately, in my experience, the morph is OK at 0.0 and 1.0, but the verts go really distorted in between. They must be pulled instead. A prop moulded in the sitting position is probably the simplest way around this.
brittmccary posted Mon, 21 January 2002 at 8:12 PM
for a newbie! I didn't get it!!! ( o)(o ) I'm having too much to figure out with TWO legs! lol Step-by-step please???? Carolly, - I'll try your approach first! Hmm... conforming FIRST then pose... Interesting... kieraw - do you remember what that was???? you mean it needs to be a prop under the skirt?? (my mind is NOT in the gutter!) Strangechilde - this sounds interesting... so in my instance, - the thighs are poking through, - and you'd set the SKIRTS corresponding bodyparts to 100% transparency??? or would you set Posettes thighs to transparency? If you look at my example it looks like the skirt is "poking up", - not Posettes thighs. I'm confused! But then, I'm easily confused! :) Britt
hermith666 posted Mon, 21 January 2002 at 9:21 PM
Attached Link: http://www.reyes-infografica.net/
Well if you have Amorphium then I would suggest using some patience and the hammer to create a morph that would fix the final position. On 3dMax, if you have any cloth simulator (like ClothReyes, the best ever), you can apply the simulation after the work is done and have the cloth of the skirt to fold over her lap. If you do not have this plugin you can download it from Reyes Infografica at the link below. A third option, still in Max, is to select some vertices and to move then with Soft-Selection on, so that the mesh gets a little softer as a vertex causes its neigbors to move with it. Eighter way, if you use 3dMax to finish your job, you'll need a plugin to import/export .Obj files, in wich case i suggest the one you'll find here: http://www.habware.at/duck3.htm Hope to be of help. Liam
brittmccary posted Mon, 21 January 2002 at 9:49 PM
Hmm... I've seen that, and wondered why people prolong the hip all the way to the floor. So that's the reason. Hmm.... Then of course I get your point how a horizontal hip wouldn't work. I've read - and read again all the stuff I could find about ERC. I find it VERY difficult to understand theoretically. Maybe if I do some practicall erroring! lol I've got CR2edit and am trying to learn that parallel to learning Amapi, Poser, Bryce, UV-mapper... g I guess I just need to be more Patient (argh... I hate that P-word!!) But... to follow the prop thought.... how would I model that, - and how would it be posed?? Liam... Thanks a bunch! I don't have MAX... :( I do understand that it prolly can make things more easy, but for now (at least!) I'm working with Amapi 6.1... and getting to like that program.. A LOT. :) Britt
Jaager posted Tue, 22 January 2002 at 12:13 AM
ERC is when a morph (or joint)is set by another channel.
A "channel" can be anything in the second section of the CR2 which is called 'channels', strangely enough.
These are morphs or joint movements mostly. Scale is a channel. Any thing that you can change the dial for, can automaticall change the dial of another, either on the same figure, or a different one. When this happens on a different one, and you do not want it to happen, it is called cross-talk. Poser 4 is sort of at v0.5 on this feature, so it is tricky to use in practice, you must CYA.
Relevant to this, suppose you had a morph for the 'hip' part of the skirt that goes to the hem. At 1.0 this morph swings the section up 90 degrees so that it fits in with the part covering the legs.
You can do the morph by hand, after you do the sitting pose. Or, you can slave the morph to the bend rotation channels (P4 thigh only) of the figure. This is a tricky example, but say 90 degrees of rThigh = 0.5 morph and the same for lThigh. So, if both legs have 90 degree bend, the morph is at 1.0. It is set automatically by bending the thighs of the figure. Enhanced Remote Control.
You set how far the morph can go with its own min/max.
You set how fast with the rate (DeltaAddDelta) on the morph itself. How this morph looks with different positions for the legs would need testing, but I think this would probably work for most poses. One morph, it does not save a lot of time, but suppose you have twenty different morphs to adjust the skirt to different poses? Or suppose you were doing an animation?
An example of ERC that is in more constant use: slave the xrot and yrot of the left eye to that of the right eye. When you move the right eye 10 degrees to the outside, left eye automatically moves in parallel. This is JCJ - joint controlled joint. The rate is 1.0.
Jaager posted Tue, 22 January 2002 at 12:27 AM
For the skirt morph, if you wanted the right leg to go no further than 0.5 - no matter what, you cannot do this and have the left be able to take it to a total of 1.0. If the right went to 120 degrees, it would take the morph to ~0.67. But, no matter how far you took the left, the morph would stop at 1.0, if this is the max. You can set the right to go no further than 0.5 - if - you put two copies of the morph on the figure - slave one to the right thigh with a max of 0.5 and the other slaved to the left at 0.5 max.
steveshanks posted Tue, 22 January 2002 at 3:46 AM
I've fiddled and fiddled for a long time trying to get sitting skirts to work but never quite was satisfied with the morph way of doing things plus its a lot of work and the time could be used to make more clothes:o).....in the end i went down two paths a prop and a posable figure the image in this message is a prop parented to the hip so what happens is you pose your figure or use a pose you already have then apply the sitting pose which only affects the hip, thighs and abdomen then you remove ik and bend the shins till the feet touch the ground (to allow for different height seats)if you need to......the second image is a skirt which has abdomen, hip, thigh and shin (just one of the latter two) and what you do is pose one side of the figures legs hip etc use symetry to pose the other side then apply the same amount of bend to the skirt..for example of the thigh on the figure is bent at 35 you bend the skirt thigh at 35...these both have obvious faults as in the poseable one you are restricted to symetry and the prop one you are restricted to the thigh and hip poses that fit in the skirt....(though we are doing cross legged versions too :o)....but the good side is they look right and you can model creases or any other sitting atributes into the prop to make it look right...having said all that check out jim burtons post in the poser tech forum he looks to have sussed sitting posable skirts out ....Steve
steveshanks posted Tue, 22 January 2002 at 3:47 AM
and the second
steveshanks posted Tue, 22 January 2002 at 4:03 AM
And one more a bit longer and more posed this time ;o)
brittmccary posted Tue, 22 January 2002 at 5:22 AM
Thank you, so much Steve and Jaager. I'll fiddle with this today, and see where it brings me. :) I'm just glad that I tried with one of the Poser skrits before I started to mess with one of my own model, - because then I'd be sure that it was my model that was wrong! :) Britt
Jim Burton posted Tue, 22 January 2002 at 7:42 AM
I gave up on the middle leg idea, I got it to work about halfway but it still had problems. I had given up on morphs a long time ago, but I revist them every so often, hoping for some inspiration. Like Steve says, life is just too short to get this working properly. The bottom line is the sheath dress in the Vickie Essentials will have two versions, a standing one and a sitting one, same mesh, different CR2s. The sitting skirt actually uses the middle leg part, so I did get something out of the exersise. I also hooked it up with ERC - Joint controled joint in this case, with the bend set to 1/2 that of each thigh, so if Vickie bends both legs the same amount everything comes out right, saves a little time anyway, but you still have to manually adjust it. With some extra morphs she can just about sit cross-leg, too, which is the real test! Anyway, as a lot of you guys already know, the last joint of a figure doesn't have to have real mesh, it can be virtual- that is how I get away with the same OBJ, one has the regular lThigh and rThigh, the other has mThigh, but all thighs are virtual. The onlty disadvantage is you have to pick that part from the pull-down menu, not off the figure.
Strangechilde posted Tue, 22 January 2002 at 6:30 PM
I'm sorry I couldn't be more helpful. I've never gotten to grips with 3D modeling, and actually ebded up deleting Ray Dream Studio (the old one, with the duck) from my machine because I never used it and needed the space. Yes, it's bits on the legs of the figure to make transparent; that way geometry that pokes through the skirt doesn't show. I just don't understand the underlying mechanics of it all. What I do understand is: Paint Over the Bit That Doesn't Look Right. Postwork is my best friend.
HandspanStudios posted Wed, 23 January 2002 at 3:36 AM
Has anyone tried making instead of a third leg an extra two parts, one between each hip and thigh that might act as a buffer? Or is there a way to make a skirt a hybrid of a poseable prop and conforming figure? That is make all the skirt parts bend manually with nothing automatic? Is that even possible? The third thing is to maybe cut the hip section so it was very small and most of the area that would normally be asigned to the hip would be the abdomen instead. Then the part with the amplified bending would be too small to have such a drastic effect?
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
steveshanks posted Wed, 23 January 2002 at 3:43 AM
The middle image i posted has the parts bent manually, but you still run into the problem that all poses must be symetrical (leg wise) i think unless poser 5 allows shins in a skirt in some way then we'll always have to compromise with sitting poses....Steve
HandspanStudios posted Wed, 23 January 2002 at 4:07 AM
I was thinking something like this. If you did this with manually controlled bending I don't see why you couldn't bend it any which way. That is more like how a real skirt is (not that that means anything). It would be more likely to work if the front and back side pannels bend seperately. It would not conform I know but would it work as a poseable prop or a non conforming figure?
Annie Dillard
steveshanks posted Wed, 23 January 2002 at 4:22 AM
I'm afraid you can't coz you would have 3 groups touching each other....its best explained on page 307 of the manual, this is what i hope poser 5 changes..if its possible of course :o).....Steve
HandspanStudios posted Wed, 23 January 2002 at 5:20 AM
Don't all Vicki skirts have 3 groups touching eachother? Doesn't pretty much everything have 3 groups touching eachother? collar/chest/collar or buttock/hip/buttock? Maybe I'm not understanding what 'group' is. I guess I better go look it up.
Annie Dillard
HandspanStudios posted Wed, 23 January 2002 at 5:40 AM
I get it now, took me awhile. Thanks, who knows how much time that saves me when I go to try something similar.
Annie Dillard
Jim Burton posted Wed, 23 January 2002 at 11:38 AM
Still need work, but as you can see Vickie can sit cross-leg in it. Right now there is a mThigh (Mid Thigh) group that is manually twisted. HandspanStudios - you sould do that if all three parts were virtual, that is to say no mesh, and all three were children of the hip. I should add "Been there, tried that", the problem you run into is getting the fall-off zones adjusted properly where they onerlap, otherwise you get ridges sticking up (or in) where two fall-off zones overlap. Maybe somebody else can get it to work, but I found it a dead end. I also found the pure morph solution a dead end too, as morphs move in straight lines, body parts rotate around a joint. Oh - the reason why no mesh is you can't weld a seam between children, Poser just ignores the command.
HandspanStudios posted Wed, 23 January 2002 at 4:49 PM
Interesting thanks. What you've got there looks pretty good.
Annie Dillard
