Subject: Change to fantasy great room textures
dolly opened this issue on Jan 22, 2002 ยท 11 posts
dolly posted Tue, 22 January 2002 at 11:59 AM
Hey all After i posted the other texture i hated it so i deleted it and started again Well this time i like it so this is the wall texture that will come with the room All comments welcome cheers dolly
ronknights posted Tue, 22 January 2002 at 12:00 PM
Are you kidding? This jumps out at you. Wow
Kiera posted Tue, 22 January 2002 at 12:02 PM
This is a much better wall texture. Might I suggest adding a bit of "bump" to the window glass to make it look a bit more like stained glass? I love what you have done so far. =)
dolly posted Tue, 22 January 2002 at 12:05 PM
Thanks all But as far as im aware you cant use bumps on a trans map as the window has a trans map cheers dolly
jwkub posted Tue, 22 January 2002 at 2:03 PM
WOW , very nice improvement! looking good indeed. happy rendering, JWKub
Ghostofmacbeth posted Tue, 22 January 2002 at 2:31 PM
You can use bump, texture and transparancy on most poser things without problem.
Barbarellany posted Tue, 22 January 2002 at 2:37 PM
For the windows, couldn't you use a quick untexturized poser scene of some characters say standing gracefully. take it into a drawing program and outline it in black, make a bump map that follows the outlines and add some light reflection map to get a better feel for stained glass? This isn't being critical, more thinking outloud and wondering if that would give a good effect.
Kiera posted Tue, 22 January 2002 at 2:46 PM
Ghost is right.. This is a pot with transparency, reflection, and bump applied, pure Poser render of both. Note that the stems of the flowers show through the top and the pot is a bit darker with the dark background.
dolly posted Tue, 22 January 2002 at 3:35 PM
Hey all Thanks for all the tips,the windows are fantasy and doesnt have to look like real ,normal stained glass : ) And i did add bumps to the leaded part it looks better but i havent posted yet,i will in couple days or so. But i will try the suggestion barbarellany cheers dolly
Kiera posted Tue, 22 January 2002 at 3:48 PM
It's your texture, I just wanted to see if the notion that you couldn't apply bump maps something that was transmapped was true. I didn't know if you could, so I tried it out just to see. =)
Jazzmin posted Tue, 22 January 2002 at 4:56 PM
I like these textures much better, good job so far Dolly! Jazz
Vive Bene.  Spesso L'Amore.  Di Risata Molto.
Live Well.  Love Often.  Laugh Much.
