romanichel opened this issue on Jan 23, 2002 ยท 7 posts
romanichel posted Wed, 23 January 2002 at 6:22 PM
I wanted to copy all the morph of Michael2 to my Mikey cr2 file,but with morph manager4, I can copy all the morph, but not the "body". Anyone, could help me? Thanks
Jaager posted Wed, 23 January 2002 at 6:38 PM
Change the extension of m2.cr2 to m2pz2. The body channels are accessable from a pose file.
romanichel posted Wed, 23 January 2002 at 7:02 PM
I copy well the body channels, but if they appear in the parameter dial in Poser, they don't are effective. They are not effect!:-(
Jaager posted Wed, 23 January 2002 at 7:07 PM
They will not be unless you also copy all the morphs that a particular dial controls. The Dials In Body Are Not Actual Morphs...
romanichel posted Wed, 23 January 2002 at 7:13 PM
I copy all the morphs of all the body parts, and all the channel of body. The dial controls of the body part are effectives, but not the dial body! Must I make another things?
Jaager posted Wed, 23 January 2002 at 8:58 PM
Did you try saving the CR2 and then re-opening it? If you did not change the name of the valueParm in Body and copied everything as is it, the only thing I can think of is that the controling figure in the ERC script is still probably Figure 1 and Mikey is not that to Poser. I have never had the dials on a figure refuse its own morphs, do another figure in addition, yes. The control figure part may not be as straight forward as it seems to be. But if save and reopen does not work, it have no other idea.
romanichel posted Wed, 23 January 2002 at 10:26 PM
Thank you for your help. It seems, I must copy body channel in first, and then the body part morphs.
