Vile opened this issue on Jan 25, 2002 ยท 8 posts
Vile posted Fri, 25 January 2002 at 12:51 PM
Ok two things that I have been perplexed about. In an animation how can a change the camera tracking to a different object without changing it globally (i.e. through the whole animation)? and Second how can I add a key frame at the begin (like insert a frame) or How can I slow down the animation or object? Thanks!
geep posted Fri, 25 January 2002 at 2:20 PM
cheers,
dr geep ... :o]
edited 10/5/2019
Vile posted Fri, 25 January 2002 at 4:25 PM
Ok...I changed the camera to track another object then the original track goes backwards and does not track the first object. How do you I select all the frames? and then shift them? Sorry I don't mean to be dense here. Thanks
geep posted Fri, 25 January 2002 at 5:21 PM
I just joined this forum 'cuz I just ordered Bryce. The advise I gave you was for Poser. Can anyone else answer these questions? (properly) ;=[
cheers,
dr geep ... :o]
edited 10/5/2019
Vile posted Fri, 25 January 2002 at 5:41 PM
Thats ok Geep we will get it figured out
geep posted Fri, 25 January 2002 at 5:47 PM
I hadda try. sniff ;=[
cheers,
dr geep ... :o]
edited 10/5/2019
VirtualSite posted Sun, 27 January 2002 at 3:54 AM
You can slow it down by increasing the fps rate and rendering as a stack of pict files, then stitching them together with something like Moover set for the original fps rate.
Vile posted Sun, 27 January 2002 at 1:25 PM
So no really way to slow down the action unless its done first? Hmmm like I said this is my first attempt at animation.
