Penguinisto opened this issue on Jan 26, 2002 ยท 6 posts
Penguinisto posted Sat, 26 January 2002 at 12:55 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=131842&Start=1&Sectionid=4&WhatsNew=Yes
Instead of posting an ugly un-textured model, check the link up top. Remove 'Nicole', remove the floor, and that would be the roof - It has a round vaulted ceiling that you can use anywhere, and not just the Artrium... (I'm using it as a 'solarium' at sunrise for this shot :) It also has a transverse beam running across the center of it that can be made transparent or textured as needed. A separate chandelier will eventually attach to it. The ceiling itself is set to almost transparent right now, just to see if the render materials assignments latched on to the polygons okay. So why is it still white? Well, I still have to bake it (the roof, not Nicole - heh.) in UV Mapper to get it textured, but I thought it would be fun to actually have some fun with it while it's being built, and to show off the pretty little redhead that Dark Whisper built at the same time. Cheers, /P
