Subject: Got TargoMagnet, now Need TargoMatSpheres
bloodsong opened this issue on Jan 28, 2002 ยท 8 posts
bloodsong posted Mon, 28 January 2002 at 9:46 AM
heyas; so... trav... and company... if we can replace the magnet zone with a target ball prop, how come we can't replace the inner and outer matsphere zones for the jps?? :/
Traveler posted Mon, 28 January 2002 at 10:52 AM
Because I don't know what geometry the inner and outer zones are calling :) It may be an internal thing. If thats the case, it's a no-go. But if someone can find them, they can be replaced by the same targo-magnet sphere.
bloodsong posted Mon, 28 January 2002 at 2:17 PM
heyas; and when you were poking around looking for the mag zone, did you find the switch that tells the magnet what preview style to use? i'm forever changing the smeggin' things to outline. well, at the advice of some persons, i copied the new targomagnet ball to the other ball, but that didn't change the matspheres. ::sigh::
Traveler posted Mon, 28 January 2002 at 2:24 PM
I "believe" that the mat spheres are internal to the code of Poser. I looked and poked around and coulden't find them. The settings on the magnets are also internal :( they are always going to pop in as shaded :( maybe in poser 5 we could have that as an option :)
duanemoody posted Mon, 28 January 2002 at 5:05 PM
Is this TargoMagnet any different from the version you posted a few years back (which I've already installed)?
saxon posted Mon, 28 January 2002 at 5:40 PM
I've often wondered whether it was possible to have a different shaped magnet zone, have you tried it with a cube? ...... (if that's not being too personal... ever had those days when everything you say has a double meaning?))
bloodsong posted Tue, 29 January 2002 at 11:39 AM
heyas; yes, it's the same targomagnet as before. if you already have it, you're fine. you can replace the magnet zone with a differently-shaped prop, but it will not affect the actual falloff zone. in other words, it may look like the stairs on screen, but it will behave exactly the same as a sphere.
saxon posted Tue, 29 January 2002 at 3:00 PM
bums
