Forum: Poser Technical
Subject: Is there anyway to do this in Poser?
Devon opened this issue on Jan 28, 2002 ยท 4 posts
Devon posted Mon, 28 January 2002 at 1:53 PM
The other day I figured out that Poser will NOT let you load more than a certain amount of Pose files and folders without having loading problems. I used to have 278 folders at 177MB. I took about 1/3 of them out and now all of them load properly. Now I don't know what to do with the other folders I had to take out. Is there anyway I can add a new catagory (Folder) to the tabs list that contains Characters,Hair,Poses,Figures,Camera and Lights?
lalverson posted Mon, 28 January 2002 at 2:49 PM
Well concidering just my figures tab has 175 folders i don't follow what you are having a problem with. the thing poser can slow down on is gerenating the RSR thumbs or the PNG thumbs in a pariticular folder. My props folder has 183 folders in there and each folder contains on average 20 items. and my poser folder is 18.9GB in size and I run win98 on a athelon 1GB with 512 MB ram
Devon posted Mon, 28 January 2002 at 6:07 PM
Glad to know your Poser Folder is 18.9 GB. I thought mine was big at 11GB. It seems that I only had problems with them loading when I got down to the bottom of the list. Usually around the t's to the z's. Maybe it's a problem with the PNG thumb generations. I'll look into that. I was only having problems with the Pose folder. I'm running Windows XP professional...1400MHZ AMD Athalon with 512MB RAM and G-Force 3 64MD video card. Thanks for your reply.
geep posted Mon, 28 January 2002 at 6:11 PM
... put your older (less used ones) on the CDROM. Then use a viewing utility like "P3do" which allows you to view 'em online without using up your HD space, no? cheers, dr geep ;=] P.S. You can NOT add more folders to the Poser "library" (folder) nor can you add a folder in one of the libraries "categories." I just tried both of these varients and neither one works. I believe the library structure is "fixed" internally by Poser. Maybe in Poser5 .... Hey Curious Labs .... you guys takin' notes?
cheers,
dr geep ... :o]
edited 10/5/2019
