Ikyoto opened this issue on Dec 30, 1999 ยท 6 posts
Ikyoto posted Thu, 30 December 1999 at 6:07 PM
JeffH posted Thu, 30 December 1999 at 8:13 PM
Seems more like a render/redraw engine problem. I saw this happen to a figure just the other day as I was using the full tracking setting. The leg buckled just like that then cleared up.
shadownet posted Thu, 30 December 1999 at 10:44 PM
You might try experimental adjusting of the scaling dials for the hand and problem join(s). I had something similar to this occur when I first started out using Poser 3. I was able to go through and manual adjust the scaling on the hand and fingers to correct the problem than save the corrected model back to the library. No problems after that.
nnuu posted Fri, 31 December 1999 at 1:48 AM
i had something like that happen to me but it was on the forearm...cant really say what i did to cause it but i couldnt fix it...sooooo...i had to start over nnuu
Ikyoto posted Fri, 31 December 1999 at 8:02 AM
Thanks.. I guess I've been looking at it from a mesh problem rather than something simple... I have a habit of over thinking the plumbing. I'll let you all know in about an hour.
Ikyoto posted Fri, 31 December 1999 at 9:56 AM
Yup! That did it! Simple answers still work best. Thanks folks. now where's that damned cat......
