Forum: Carrara
Subject: MetaBalls
Grimpup opened this issue on Dec 30, 1999 ยท 10 posts
Grimpup posted Thu, 30 December 1999 at 9:36 PM
I have created a form using MetalBalls. If I apply a custom texture it dose not render. Color shaders and the likes work fine, texture map is a no go. Help.
ClintH posted Fri, 31 December 1999 at 9:59 AM
Hi GrimPup, I havent played with the MetaBall modeler in Carrara yet. So, This morning I did a little test. Created a few metaballs posative and negative..ended up with a funky shape. Went into the Texture room and loaded a T-Map into the color channel and it DIDNT display the T-Map. It changed colors but the T-Map wasnt shown when I rendered. Looks like a problem to me or a limitation in the MetaBall Modeler. Clint
Clint Hawkins
(Zakk Wylde (2007))
hund posted Fri, 31 December 1999 at 11:31 AM
I can shade my metaball objects with carrara using texture maps. try applying the shader to the objects in assemble mode.
martialf posted Fri, 31 December 1999 at 1:03 PM
Me too i can shade a metaball objet in assemble window i just did it with a objet lookslike a weird dog and a texture drag from shader browser:see it on shading,on fast render button and on a rendering window It is on a PIII and 256 ram and Win98se
ClintH posted Fri, 31 December 1999 at 4:17 PM
hund & MartialF, Shaders appear to work fine. Are you using Texture Maps in your Color channel in the shader? Its Texture Maps that we seem to be having a problem with. Clint
Clint Hawkins
(Zakk Wylde (2007))
martialf posted Sat, 01 January 2000 at 4:50 AM
I just try it ,CLinth.You are right i make a metaball ,go to shader ,put a map on color layer,go to assemble room and metaball not render with texture I also create a shader with only texture for a vertex objet,save it on browser,try after to put on metaball objet ,no rendering.Hope a patch will correct it
ClintH posted Sat, 01 January 2000 at 9:18 AM
OK - Whew! I thought I was loosing it. Thanks for replying on this. Happy New Year to you. Talk with you soon. Clint
Clint Hawkins
(Zakk Wylde (2007))
Grimpup posted Sun, 02 January 2000 at 12:17 AM
Ok. Change the mapping mode to flatmapping and the texture will appear.
martialf posted Sun, 02 January 2000 at 5:27 AM
I try now Grimpup.Thanks.It working also with parametric or other mapping mode .You just must select one.
ClintH posted Sun, 02 January 2000 at 9:32 AM
AHHH YEEE!!! Thanks guys. Clint
Clint Hawkins
(Zakk Wylde (2007))
