Forum: Carrara
Subject: Physics model extension news
tkane18 opened this issue on Jan 29, 2002 ยท 8 posts
tkane18 posted Tue, 29 January 2002 at 1:08 PM
A prior post suggested contacting Eovia about getting the physics stuff to work if you are a C1.1 user with a C1.0 CD.
Their response was as follows:
Truly, I do not know the exact procedure but I bet it wouldn't be too difficult to figure out. With consideration given to business etiquette and/or political correctness, it probably wouldn't be very prudent of us to make such information readily available anyway.
In any case, we should get license for use very soon.
keithw posted Tue, 29 January 2002 at 4:24 PM
It's about time I got tired of waiting and installed the version 1 physics into version 1.1. All you have to do is copy three files from the Carrara 1.0 "Ext" folder to the Carrara 1.1 "Ext" folder. The files are WmDme.dll Physics.dta Physics.mcx (I think thats the right extension I'm working from memory on this one. The post that I found on the Carrara's Yahoo group had the wrong file extension so I just copied the two files that said Physics and the DLL)
tkane18 posted Wed, 30 January 2002 at 9:25 AM
I ended up copying the files also.
pixelicious posted Sat, 02 February 2002 at 4:00 AM
what are the physics models you speak of? (forgive me. i just began using carrara two months ago beginning with version 1.1)
tkane18 posted Sun, 03 February 2002 at 12:03 AM
You can apply real life forces to objects to simulate gravity and directional type forces. So instead of starting an object at point A and then setting point B and applying a tweener, you can set the object at point A, apply a force and let that force control the actual movement and outcome.
litst posted Sun, 03 February 2002 at 3:28 PM
Pixelicious, the physics were included in the first release of Carrara by Metacreations . When Eovia released its own version, the physics plug-in was not included because of some licensing issues . They promise it will be back in Carrara, though .
pixelicious posted Mon, 04 February 2002 at 2:19 AM
thank you litst and tkane18 for the explaination. by, the way litst, i stumbled onto your site a couple weeks ago. your work is very nice.
litst posted Mon, 04 February 2002 at 2:36 AM
Thanks Pixelicious :)
