Subject: Morph targets...
ledenko opened this issue on Jan 29, 2002 ยท 5 posts
ledenko posted Tue, 29 January 2002 at 1:41 PM
This may be a silly question, but... I have an Orc for Michael model and would like to know, if I could use Michael 2 morphs on the orc model (Michael 2 has a sharp teeth morph and i'd like to see it on the orc). Thanks!
Crescent posted Tue, 29 January 2002 at 1:56 PM
Worst case scenario, use Morph Manager to move the morphs from Mike 2 to Mike 1.
igohigh posted Tue, 29 January 2002 at 2:47 PM
Maybe Morph Manager. Last night I tried saving out a head morph from Mike-1 and then apply it to Mike-2 but Mike-2 claimed it was not from the same mesh??
geep posted Tue, 29 January 2002 at 4:43 PM
... you can't transfer MTs. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Routledge posted Wed, 30 January 2002 at 6:32 AM
Mike 1 and 2 should be identical meshes. Set the sharp teeth morph on Mike 2 only, no other morphs, then export the head only as an OBJ. Deselect all tickboxes except "save as morph target" then save it and load it onto Orc Mike then it should work fine. This assumes the Orc Mike you have is vanilla, ie you haven`t edited it and re-stitched the head onto the origianl model.
