Subject: Morph Manager 4.0 now in free stuff
Mason opened this issue on Jan 02, 2000 ยท 14 posts
Mason posted Sun, 02 January 2000 at 1:30 AM
Attached Link: Mr. X Poser Page
Morph Manager 4.0 is out. I'm sure it has a few bugs but appears pretty stable. Again, please backup your work before using. Here's a list of changes and additions: 1. Now more robust. Handles a lot more odd cr2 files. 2. Support for other file types like pose files, hand files, face files and pz3 files. 3. Bug fixed where two cr2s with a different number of body parts wouldn't transfer morph targets incorrectly. 4. Prop support now in. You can copy props, delete them, rename them and edit their morph targets and also combine morph targets on props. 5. Much more robust properties dialog that allows editing of all values. 6. Fixed bug where some MAC obj file versions would not load. 7. Now allows separate obj files loaded for each cr2 file. They don't have to match. 8. Drag and drop now works with obj files as well. 9. Help preferences for fixing the storageOffset bug, removing unused materials and adding unreferenced materials into the cr2. 10. Help button now attempts to run your default browser to view the help.html file. The prop support and pose file support are the two big things. You can now transfer pose information from one hand, face or pose file to another so you can mix and match poses. You can also remove those annoying morph targets from a pose so your face and body settings don't get messed up anymore when you apply the pose. http://www.geocities.com/mr1_x_1/ will take you to my site where you can find the zip file and other items.
