lordal opened this issue on Feb 03, 2002 ยท 4 posts
lordal posted Sun, 03 February 2002 at 9:16 AM
I'm trying to add a couple of items to a scene but they will not show up, tried the bow and arrows from the wood elf pack (the earings in the same folder work) loose socks from two-swords and a couple of other items. You can click on them and alter the dials etc, but they won't show up. I have checked that they are visible, tried re-installing the files, deleted the rsr's, they don't appear when rendered. I have Pro pack installed if that could be of any cause?
Help!
ronknights posted Sun, 03 February 2002 at 9:43 AM
Just out of curiousity, have you installed the Poser Pro Service Pack 3?! If not, get over to the Curious Labs site and get it. OH, and Poser Pro Pack doesn't use the rsr files. It uses png files instead.
Bongo posted Sun, 03 February 2002 at 10:26 AM
I've had the same kind of problem (no Pro Pack installed). Click on a prop from the props library, it loads - but is "invisible". I re-imported the original prop and re-saved and it works.
lordal posted Sun, 03 February 2002 at 12:47 PM
for the replies, no success so far but I'm sure I'll figure it out. Bit new at this forum thing, I've deleted my earlier replies does that delete them for everyone? Sorry if thats the case.
