Subject: Need help with Prop!!! - please
cwshorty opened this issue on Feb 03, 2002 ยท 10 posts
cwshorty posted Sun, 03 February 2002 at 5:11 PM
Ok, so I started out determined to make just a simple necklace and ended up with something completely different. However it's my very first Poser Prop yipee and if I can get it right it will be in freestuff - that's if anyone whats it!!! Obviously it's not ready for the texture yet but my problem is I can't seem to get all of the legs even. Each piece is separate but the legs are parented to the table-top and then locked. But as you can see they aren't even, please tell me there is a really easy way to do this. Any help at all would be sooo appreciated.
peejay posted Sun, 03 February 2002 at 5:28 PM
Sorry if I seem a bit dim, but I don't understand your problem. You make one table leg, then copy and paste it another 3 times ( or save and import if copy and paste don't work) Or are you meaning 'even' as in positioning and spacing? What software are you making it in?
shadowcat posted Sun, 03 February 2002 at 5:35 PM
you must take into account perspective when veiwing at an angle, look at it using the front & side camers
Penguinisto posted Sun, 03 February 2002 at 6:21 PM
First, un-parent the critters. Then, get your angle so that the table is dead-on broadside, and the top is flat... then adjust each leg. Select the camera you're usinig so you can get it's dials... spin it so that you're facing the end of the table, again with the top level. make any further adjustments to the legs then. Once all legs are level and even with each other, re-parent 'em to the table. et voila' - your legs are straight again :) /P
cwshorty posted Sun, 03 February 2002 at 7:27 PM
Thank you, I'll try it again. Ugh!!!
geep posted Sun, 03 February 2002 at 10:01 PM
... center the table top in the Poser studio and then position the table legs using the parameter dials. Just set the legs with equal offsets (xTran) except the one on the left will be a negative number and the one on the right will be the same number except it will be positive. Rotate the studio cam (or the table top if you parent the two legs already positioned first) 90 degrees and repeat for the other two legs. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cwshorty posted Sun, 03 February 2002 at 11:58 PM
Thanks geep! BTW - I have a niece that I call geep - I know you were just dying to know that. LOL Thanks again!
geep posted Mon, 04 February 2002 at 12:21 AM
... make like a 4x4? I can! ;=] [you know j.e.e.p ......... JICYDUT] How does she pronounce her name? [just curious]
cheers,
dr geep ... :o]
edited 10/5/2019
cwshorty posted Mon, 04 February 2002 at 12:23 AM
LOL!! I'm pretty sure she can't, it's like jeep only with a g should instead of the j. She hates it too. LOL %^)
Penguinisto posted Mon, 04 February 2002 at 9:51 AM
(and I own it :p ) /P
